New Battery Tracker Plus From Antigravity Batteries!
Premium Sponsor
Antigravity Batteries has just released our NEW version of the Battery Tracker called The Battery Tracker PLUS+ which has been updated significantly and has many new features compared to the original version.
Changes that we've incorporated on the Battery Tracker PLUS+ are:
-You can now Monitor 4 applications at one time so you can see the live voltages and State of Charge of 4 vehicles all at once. Additionally, an unlimited qty of vehicles can be put into the App versus the prior version which allowed a max of 5. If you wanted to see alternative vehicles you have paired you'd have to switch which 4 cars you would want to monitor at a time, but it only takes a few seconds to switch to another vehicle. This works great if you have a few cars in your Garage, Collect them, or have a fleet. This can also work great if you have other vehicles or applications such as ATV's, UTV's, Motorcycle's, Boats, Trailers and anything else utilizing batteries so you'll be able to see when a battery may be getting low and is in need of charging.
- You can name each vehicle so they show up by name or whatever you choose.
- You can now monitor 6v, 12v, or 24v batteries in cars and other vehicles , or if you have any battery system that you want to check on. So you can connect these multiple battery voltage options now instead of only 12v as on the original Battery Tracker.
- You can now monitor Lead/Acid, Lithium or other battery chemistries with the new model, no buying a specific version anymore. We have standard settings for Lead Acid and Lithium batteries, but you can input your own settings if you have a different battery chemistry or want to enter a customer parameter for your particular use.
- The App has been updated and it is actually a completely different App you download due to the new options and features, and as mentioned above offers the ability to track 4 vehicles at one time... each vehicle is signified by a different color in the graphs and readings, so it's easy to tell them apart...
- Connecting to additional Battery Trackers is super easy due to it finding them and loading them when the app is open. Also it walks you through the set up procedure for the type of Battery. For example, vehicle or system, Lithium or Lead, parameters you want etc....
- In the History area of the App you can now see Voltage, State of Charge or Temperature as Historical Graphs... instead of just voltage only as before. You can also select 1-day, 3-day or 5-day history graphs instead of just one day at a time which is great when looking for specific data.
- One of the big things we were asked for was Downloadable Data.... and now you can download a spreadsheet of the data for the historical voltage and other data points.
- Another new feature is the "Find Car" option which works well for its intended use... For example if you go to some event or anywhere actually, the Battery Tracker will track your last location when you turned-off the car or vehicle. A good example would be if you were parked at an airport and may have forgotten which terminal you were parked at because a different exit or entrance was used. It will also work if you are at a big event and forgot where you parked your car at a stadium or something similar.
- The Tracker Plus can also be used to track mileage and cost of travels and such because, it links to your phone's GPS and tracks miles driven, you do have to input some data then it will use that input to track and provide costs.
- The new Battery Tracker still only draws 1ma of energy which is inconsequential in terms of draining the battery in your car, 1ma is exceptionally low. However as with any App communicating with a Bluetooth device it can cause a phone drain similar to what other Bluetooth apps might. Not more and it is not fast, but just similar to what other Bluetooth devices do.
- It has limited but functional use with the Apple Watch as an App. So you will be able to see some data like the voltage and such. We are uploading that to Apple in the next few days.
- It works via Bluetooth so you can get your data if you are within about 25-30 ft of the vehicle in most cases. Seems to be fastest if you are about within 20 ft of the vehicle when it transfers its data into your phone App.
- As with the previous version it has 5 minutes of your real time voltage in a Real-Time Graph which is great for analyzing voltage sag from certain accessories, or for using it as a multimeter if you are working on anything with your car.
- As before it also has an automatic Starting Test feature, which shows voltage sag during your last start attempt. Voltage sag can indicate a battery losing its ability to provide a good level of cranking which can also indicate it may be going bad, or is too low.
-As before it has an Alternator Charging Test feature... with a few more test variables in diode ripple voltage.
- Normally it should take about 2 minutes to attach to your battery and a few minutes to put the App on your phone and you'll be up and running...
- We have a new design that is a take off on our MICRO-START Jump Starters Shape.. to help keep the look inline with our current products... and you can also tell if the unit is on now physically because it has a tiny LED that blinks every 4 seconds on the Battery Tracker itself which the previous version did not have before....
Please feel free to check out the Video below and as always let us know if you have any questions at all.
