JRZ RS Touring Coil Over Kit
Basic Sponsor
*Bolt In OEM Replacement: Each kit comes complete with everything needed to be a bolt in replacement for the OEM coil overs. All fully compatible with the OEM top mounts and suspension.
*Competitive Pricing: Starting at $2,795, now get the same JRZ RS Sport performance and reliability at a significantly lower and more affordable price.
*JRZ Race Technology For The Street: Repackaged from our RS Sport design, the Touring series retains the same high performance design. The result is a smooth ride on the street, with reduced body roll and quicker response on the track.
*Single or Double Adjustable: Choose from our single or double adjustable designs, in addition to height adjustability. The wide adjustment range can accommodate significant spring rate changes without revalving, if desired later. It also allows for both a smooth OEM like ride on the street, and aggressive damping for the track.
*Predetermined Valving & Spring Rates: JRZ takes the guesswork out of the equation by choosing the optimal rates and valving for an aggressive street setup, with full track potential.
www.Tarett.com | Sales@Tarett.com | 858.674.5573
Check out our new Suspension Package Designer
