Mark this thread as Unsold
2007 Porsche 911 Carrera S Coupe 6 speed
Year: 2007
Make: Porsche
Model: 911
Mileage (numbers only please): 123769
Color: Atlas Grey Metallic
VIN: WP0AB299X7S731755
Price (no $ sign please): $32000
Private or Dealer Listing: Private Listing
Location (Region): SoCAl
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
- Gundo OEM mufflers
- Billy Boat Headers
- Evolution Motorsports intake
- GT3 Throttle body
- IPD Competition Plenum
- GiroDisc rotors w/OEM pads currently installed
- Pagid Yellow RS29 Race brake pads (used for 3sessions) not installed currently but included with sale
- H&R sport springs for PASM
- Fabspeed Muffler Bypass (not installed currentlybut included)
- Porsche OEM center radiator
- Quaife Limited slip differential
- AASCO Billet Aluminum light weight flywheel
- Sachs sport clutch disc (sprung)
- RSS Dogbones (adjustable)
- RSS Wheel spacers 5mm front/15mm rear
- GT3 rear brake cooling ducts
- Function First slip in transmission mount
- X51 oil pan guard
- Mobridge Bluetooth phone and audio kit w/USB andAux input (CD changer not connected)
- Fresh Porsche OEM PASM shocks at 115k miles
- 19 Lobsters with Pilot sports at 65% tread remaining (not installed but includedwith sale)
- 19 Sport Design wheels plasti dipped burntbronze with Toyo R888s at 95% (currently installed)
- LED fog lights
- Depot LED Tail lights
- Zunsport black grill guards
- Alcantera Shifter
5/12/2015 at 114,555 Miles:Pre-Purchase inspection completed. Leakdown/compression check and cylinders boroscoped. All cylinders under 4% leakdown and no borescoring. Vehicle purchased on 5/13/15. $367.50
6/20/2015 at 115,112 Miles: Replaced Starter and starter/alternator cable to correct slow start concern. Installed muffler bypass (Gundo hack). Mobil 0-40 oil change and Mahle Filter. $1,997.30
7/15/2015 at 115,589 Miles: Installed new Porsche PASM shocks and H&R Lowering springs (1.5), RSS rear adjustable control arms, RSS 5mm front spacers and 15mm rear spacers installed w/new hardware and 4 wheel alignment. $5,124.78
9/20/2015 at 115,984 Miles: Installed Mobridge Bluetooth phone and audio with USB port. $1409.00
10/04/2015: Installed LED fog lights and Depot LED taillights.$ 1384.66
10/21/2015 at 116,560 Miles: Installed new 350mm Girodisc rotors. Purchased Pagid RS29 yellow pads. Performed brake bedding with OEM used pads. Installed Porsche Center Radiator, coolant flushed, 160 degree thermostat installed. $4,412.62
10/23/2015 at 116,620 Miles: Zunsport front grill covers, Function First Transmission mount, Torque Solutions Semi-Solid Engine mounts and GT3 rear brake cooling ducts installed.$1227.33
11/03/2015 at 117,985 Miles: Mobil 5-50 oil change & Mahle Filter. Purchased Toyo R888 Tires (heat cycled) Castrol SRF Brake fluid flushed. $1817.50
11/08/2015 at 118,235Miles: Toyo R888 tires mounted/balanced and Pagid brake pads installed. $415.00
11/09/2015 at 118,325Miles: Performed three 15 minute sessions at Chuck Walla raceway.
11/11/2015 at 118,438Miles: Mobil 5-50 oil change & Mahlefilter. Mount Balance Michelin tires. Removed Pagid Yellow race pads and install OEM. $570.94
5/19/2016 at 120,489 Miles:Dual mass flywheel failure. Installed Aasco LWFW, Sachs sprung sportclutch disc and new Sachs pressure plate/ T/O Bearing. Precision Motorwerks in Anaheim Installedn ew Quaife torque biasing Limited slip differential with new OEM shims and OEM diff bearings.Trans filled with Mobilube PTX. New RMS seal installed. Billy Boat Headers, new GT3 Throttle body, newIPD Comp Plenum with new rubber intake o-rings from Porsche and Evolution Motorsports Intake installed.Mobil 5-50 oil change and Mahle filter. $8,499.49
10/15/2016 at 121,320 miles: Mobil 5-50 oil change/ mahle filter. Removed Torque Solutions Engine mounts(sold)Installed new OEM engine mounts to reducecabin noise/vibrations. Installed X51 oil pan guard. $1172.36
4/29/2017 at 123,452 Miles: Acquired a set of used OEM 19 Porsche OEM Carrera Sport Design Wheels. Installed Toyo R888 tires. Wheels originally chrome. Plasti Dip four coats black then finished with Burnt Bronze. Mobil 5-50 oil/Mahle filter. New battery $1412.84
Exterior Condition: As you can see in the photos the front bumper has some blemishes and chips in the paint. Some idiot decided to back into me at a stop light a few weeks ago. I have the vehicle scheduled next week to go in to have the front bumper reconditioned and will include that as part of the sale. There are a few other minor chips in the paint on the rear bumperettes and lower right corner of the rear bumper. There is a scratch in the paint about .5long on the top of the wheel arch on the front right fender. Small ding on the top of the hood left side near the windshield. Both wheel sets have some minor curb rash but the Sport designs hide it very well with the plasti dip. Underside of front bumper has the typical scratches and scuffs from curb stops.
Interior Condition: Just normal wear and tear on the center console, key surround and window switch surrounds. Driver/Passenger seat bolsters are in great shape with no rips or tears. Climate control assembly is new so there is zero wear which is common. Radio ***** could be replaced as they are a little sticky. Back seat bottoms have been removed but are included in the sale. A few scuffs on the edge of the seat backs from passengers getting in and out. No odors or smells in the car (non smoker). Cup holders in perfect working condition with no sagging. No stains in the carpeting and new OEM black floormats just installed.
Mechanical Condition: Everything on the car excluding the CD changer (disconnected for Mobridge input to PCM) is in proper excellent working condition. There are no fluid leaks of any kind. RMS was just changed when clutch was done. Ignition range report shows 21 stage 2 over-revs see photo below.
Road manners: Vehicle is very tight on the road but isnt floaty like it would be with the stock suspension, I rarely use PASM sport mode as it is almost too firm. There is no wind noise or vibrations at speed. I just removed the Torque Solutions engine mounts and installed new OEM units to reduce cabin noise. TS mounts are already sold and not included with the sale. The Aasco flywheel allows revs to come up quickly but you get a noticeable gearbox noise when transmission fluid is hot and in neutral with clutch engaged. I cannot hear the gearbox chatter with windows up or during normal acceleration. Toyo R888 tires are currently installed. They are a tad noisier than the very quiet Pilot sports. I have changed the oil every 4-5 months or max 3,000 miles and have never experienced any oil loss/consumption.Never had any puffs of blue smoke at startup.
I am located in Redondo Beach,CA. Happy to assist with delivering car to any local shop for PPI. I have a ton of photos, Carfax/autocheck, service receipts, recent Ignition report and buildsheet ready to share to prospective buyers. Would love to see the car go to a Renn-lister first and foremost but the car will go to other marketing sources after a week. Feel free to PM me with any questions. Thanks for looking.
Michael
Bummed for you to sell her, but family comes first. I did the same thing years ago. You'll get back in to a 911 before you know it. They become an addiction as you know. Hang in there brother!
