Mark this thread as Unsold
1992 Mercedes Benz 500e
Year: 1992
Make: Mercedes-Benz
Model: E-Class
Mileage (numbers only please): 74800
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Black Pearl Metallic
VIN: WDBEA36E6NB765067
Price (no $ sign please): $34500
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Cabriolet
Transmission Type: Tiptronic
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
This 500e is a two-owner example that is completely stock and drives and performs as new, even smells new. Clean CarFax. All equipment functions as designed. I even sent the original Becker radio off to be repaired and now works perfect. Original exterior paint exhibits some frontal rock chips and several small dings. No rust can be identified anywhere, including in the vulnerable battery/trunk area. The interior is nearly perfect with a new OE headliner and just several minor nicks in front and rear center console wood. All leather surfaces are as new and very soft . Most importantly, all of the following has been completed within last 1000 miles and costing nearly $20k.
Blauschwarz Metallic/Black Pearl Metallic Paint (7122) – Main Body Color
Alto Gray (7700) – Lower Cladding Body Color
Gray Leather Recaro – Interior
more detailed photos: https://flic.kr/s/aHskKwMDGp
here are all the maintenance items I've taken care of:
Body/Chassis
Headliner R&R
Headlight Switch – MB OE
Headlights – DEPO Std 124 w/ MB OE Harness Plugs w/ City Lights
Headlight Wiper Delete – MB OE Covers Painted Upper Body Color
Front Turn Signal Lenses Orange – TYE
Fog Light Lenses – MB OE
Wiper Blade Assembly - MB OE
Windshield Fluid Reservoir – MB OE
Front License Plate Filler – MB OE
Radio/Tuner/Amps – Becker Factory Complete Rebuild
Engine & Transmission
Ignition Distributer Caps and Rotors - Bremi
Spark Plugs – Proper 0 ohm MB OE
Air Filters - MB OE
Accessory Belt - MB OE
Radiator & Thermostat
Coolant Flush – Zerex G-05
Coolant Hoses – Radiator, Heater & Expansion Tank - MB OE
Oil & Filter – Castrol GTX 20w-50 w/ MB OE Filter
Engine Mounts
Shifter Rod Bushings – MB OE
Fuel Filter – MB OE
Steering
Center Link
Damper
Tandem Pump Reservoir Reseal
Power Steering Fluid Flush & Filter
Power Steering Hose
Suspension
Front Sachs HD Struts
Front Strut Mounts
Front Lower Control Arm Bushings - MB OE
Rear Subframe Mounts - MB OE
Rear Upper Control Arm Links - MB OE
Rear SLS Fluid Flush
HVAC
Upper and Lower Temp Sensors - MB OE
Upper Temp Sampler Pump
Cabin Filter
R134 Evac and Recharge
Driveline
Trans Mount
Trans Cooler Hose
Trans Fluid Flush & Filter – Castrol Transmax Mercon V w/ MB OE Filter
Front & Rear Flex Discs
Driveshaft Center Bearing and Carrier - MB OE
Differential Oil – Castrol Syntrax 75W90
Brakes
Rotors – Zimmerman Z-Coat
Pads – Porterfield RS4
SS Brake Lines – Goodridge DOT
Sensors – MB OE
Fluid Flush – Castrol LMA DOT 4
Tires
Five (4 + Spare) BFG G-Force Sport Comp2 (255/50-16) on MB OE Wheels
please contact Jordan 863 224 seven two zero zero
leave a message if I don't answer and I'll call back asap, thank you
That looks like a very nice example.
If you haven't already, you might list it on 500eboard.com too.
I wish I was ready to pull the trigger, this would definitely be a keeper example and having owned the Pearl Black I'm fond of the color on the 500.
B/T/W, Jordan is friend of mine helping sell the car. He can be reached on his cell listed above. The car is located in Lakeland, FL, just South of I4 between Tampa and Orlando, so access is easy. I will try to quickly answer any questions posed here. Finally, my 1988 944 TS is on its way to Dubai. Great buyer with large P-car collection. For those of you who know me, this all original 500E is just as nice as the 944TS. Thanks, Mike
had the same car - but pearl black on black interior. fantastic cars, built like tanks.
