Mark this thread as Unsold
2013 Subaru BRZ - Track Car
Year: 2013
Make: Subaru
Model: BRZ
Mileage (numbers only please): 13000
Options (Please check ALL which apply): Air Conditioning, Antilock Brakes, Intermittent Wipers, Power Brakes, Power Door Locks, Power Steering, Power Windows, Traction Control
Color: black
Price (no $ sign please): $22500
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
I have the car on eBay but here are some details:
The car is in perfect running condition and ready to hit the track right away. Not a single thing would need to be done to go on the track tomorrow. No shaking, no electric gizmos problem, everything just works.
My car is a fresh build without the headache and time wasting, buy it today, track it tomorrow
Spare yourself the time, frustration and cost of building one yourself !
Here are some more details:
CAR:
- 2013 FRS Raven black (black metallic)
- 13,500 miles
- engine, transmission are stock
WHEELS:
-- XXR 17x9 rims with BFG R1 245-40x17 ($1500)
BRAKES:
-- AP RACING big brake kit with braided brake lines ($2,000)
-- Carbotech XP10 brake pads front / rear (brand new)
-- APR brake ducts with carbon fiber bump inserts and rotor adapter ($600)
-- Perrin brake master cylinder brace ($50)
SUSPENSIONS:
-- RaceCompEngineering Tarmac2 2 way coil overs with 500lbs springs installed and 400lbs spring available ($2500)
-- Ground control front camber plates with aluminum truss - anodized grey ($800)
-- RaceSeng rear camber plate with 2" drop ($300)
-- Whiteline differential mount bushing insert KDT925
-- Whiteline crossmember bushing insert KDT922
-- Whiteline gearbox bushing KDT926
ENGINE:
-- mishimoto oil cooler ($500)
-- mishimoto radiator ($350)
-- HKS magnetic drain plug
-- Open Flash Tablet (running latest ECU firmware) ($400)
-- perrin inlet hose (purely esthetic) ($100)
SAFETY:
-- Full roll cage with daytona bars on both sides - stamped by SCCA this year. NASA compliant. ($3500)
-- Fire extinguisher (halon) with roll bar brackets. ($150)
-- Cage foam pads on driver side
-- momo daytona seat with 6 point harness Scrotch ($1100)
-- momo steering wheel - mod 07 350mm ($250)
-- steering hub with NRG quick release kit 'black gen 2.5' ($100)
-- Aluminum tow hooks front and back ($100)
COSMETIC:
-- Aero underbody panels (Japanese OEM). ($200)
-- interior fully resprayed Raven black same as outside color. ($1800)
-- Door panel and dash trims cut to fit with the rollcage
MISC:
-- GSpeed gas pedal relocation kit (higher and to the left for perfect heel and toe) ($200)
-- Air Horn 130dB for the hard to get point-by ! ($100)
-- Spot Trace GPS ($100)
-- Electrical interior harness trimmed to removed all Airbag and Radio wires.
SPARES coming with the car:
-- OEM Stock suspension
-- Front OEM stock brake calipers
-- Front Rotors DBA 5000 series T3 2 -pieces
-- Front Carbotech XP12 Pads to fit OEM caliper (brand new)
-- Rear Carbotech XP12 Pads (new in box)
-- oil pressure sensor unit AEM 150psi, with oil galley plug to match
-- perrin rear shifter bushin (new)
-- 2 fully gutted doors with home made set of Lexan windows, much lighter but not very convenient.
-- AC pulley only (no compressor behind it) in case you want to go without the AC.
-- Enkei RPF1 17x8 +45 with "rain tires" yokohama ad08 225x17 ($1500)
-- Toyota obd2 cable with tech stream software ($100)
If interested I have an open aluminum trailer (Trailex) for sale at additional cost. I am getting out of he hobby for now.
If you count only the cost I have in parenthesis that is $15,200 alone. Add 100 hours labor AND the cost of the car and you get my cost to build which was around $35k. The biggest point really is to get a sorted car right out the door. It was really time consuming to get to this point.
The car is located in Fort Lauderdale. Title on hand. It is a salvage title. I bought the car from Copart with a minor accident front impact. I have photo of the car before the build started, showing the damages and build process.
The car is NOT tagged and NOT street legal
If you are not local, I will ask for the funds to clear before shipping can be arranged.
IMPERFECTIONS:
What I would do if I were to keep it: add custom full body wrap or re-spray the front end that is still in primer color. I would also go ahead and add a nice data acquisition system along with a cool shirt system. That's about it. Keep the engine stock and you'll avoid any trouble and down time at the track.
Here is a list of things to consider:
-- dashboard open at the passenger airbag location, could be patched easily or replaced, dash comes out in 10 minutes.
-- center console plastic scratched
-- 'side skirt' under driver door has dent. only cosmetic not structural
-- fender and hood are not painted
-- door have small dings and scratch, 7/10 condition
-- front turn signal not connected, makes it easier to remove the bumper. rear one work
-- windshield washer container removed, I have all the parts stored if needed.
-- heater core is not installed. I have the part and could be added easily but knee bar from roll cage would have to be removed. AC and blowing fan are working with dash controls.
I have added more images in the following dropbox folder
That would be a great entry level race car for someone. They handle well, not overpowered and it's cheap. I suspect that it's the wrong brand for this lot but good luck with sale.
Weekly bump.
I spend the day at homestead after the car was stored for a month, unloaded form trailer, drove hard all day, and back on trailer, did not even have to open my toolbox aside of tire pressure and torque lug nuts.
It is really a good care free track car with all modern safety engineering behind it.
I had the car weighted at 2540lbs during my last alignment. The car at the time had gutted doors and no AC (compressor, radiator, dash blower assembly).
Since then for convenience I added glass and electric motor to the windows and a functional AC.
About power right now the car is 100% stock, manufacturer says 200HP. Dyno certainly show something around 160, if I look at forums on base cars.
I never raced the car, so I would not know.
It is 100% stock in terms of powertrain.
Only modification that could impact classification are: oversized brakes and 2 way coilovers.
Aside of that I assume weight would be the main factor in terms of class.
You can read this thread about class:
http://www.ft86club.com/forums/showthread.php?t=81256
But here is an excerpt:
There are a couple of individual drivers to follow though:
Phastafrican (NASA PTD):
http://www.ft86club.com/forums/showthread.php?t=72007
Michelle Abbate (racing in USTCC):
http://m1cheleabbate.com/
Element Tuning (Wheelen TTU class):
http://www.ft86club.com/forums/showthread.php?t=42326
http://elementtuning.com/
BP3D (Canadian Super Production Challenge):
http://www.ft86club.com/forums/showt...hlight=pumalex
Evasive (Pike's Peak and Super Lap):
http://www.ft86club.com/forums/showthread.php?t=78307
So where can the car race? Actually.... lots of places. What it takes to be competitive there is a difference story.
1. NASA Performance Touring (I'm biased so that's #1.. lol): NASA allows you to build the car to whatever specs you want and fall within a classing system. This system is the same used in the NASA Time Trial program... and the rewards/contigencies are the same. So you can decide to compete in TT until you cage the car with the same mods and hop straight into w2w. There are about 7 cars across the country, and 5 more expected to be completed this year in the Northeast.
2. SCCA T4: Only coilovers allowed at this time, but Marty Grand (multiple SSCA champion) is pushing to have this changed to make the car more competitive.
3. SCCA STL or STU: More mods allowed, but again, classing issues to make the car competitive.
4. PWC TC: I get tired of remembering all the rules, but it's actually a competitive package... just needs a little more power to run at the front
5. IMSA CTSCC ST: About 40hp shy of getting to the power limit with the currently allowed engine mods.
6. PBOC: They'll class they car when you show up at the track... but it's not the most robust system so other cars will be over classed too.
7. EMRA: Very similar to PBOC classing.
8. WRL (world racing league): A BRZ competed this year in one race... I like their classing system by lap time deltas.
