Mark this thread as Sold
Cayman S Race Car
Cayman S Race Car
Year: 2006
Make: Porsche
Model: Cayman
Cont. Porsche Models: Cayman S
Mileage (numbers only please): 1
Color: grey
Price (no $ sign please): $58500
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 4 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
New Engine (3.4 factory crate motor), installed by local dealer
This Car was originally Built by RebelRock Racing out of Florida (rennsport-one).
Below is the original build sheet. Followed by a list of upgrades done after I purchased the car.
2006 Cayman S
Body-
997 GT3 Front Clip ( Includes Fenders, Cup Car Bumper, Lights ) ** ALL OEM
Cup Car Front Splitter ( PMS )
997 RSR Yellow Lenses (PMS )
Cayman Interseries Rear Spoiler
Sparco Hood Pins
OEM GT3 Fender Liners
Cup Car Tow Hook ( PMS )
Chasis-
PMS Grand Am Control Arms ( FRONT & REAR ) Solid Thrust Bushings and Heims
ERP Front Bump Steer Kit
ERP Rear Toe Steer Kit
MCS ( Motion Control System ) 2-Way Coil overs ( Remote Res's with Quick Connects ) ** Custom Brackets for RES on ROLL Car and inside from TUB
Tarret Front Camber Plates
Tarret Cone Style Rear Camber Plates / Shock Mounts
PMS RSR Electric Power Steering PUMP
1 3/4 Inch Chromoly Cage ( TIG Welded by Lucas Fab ) Painted Silver
Fabspeed Rear Jack Plate
Engine-
Custom EVOMSit Flash
Custom Long Tube Headers
LucasFab Race Exhaust with X-pipe ( The sounds and gains are amazing )
IPD COMP Plenum
GT3 Throttle Body
Custom 4 inch Intake ( Mandrel Bent from MAF through fender wall into inlet )
997 "S" Intake Manifold (yields much more volume of air )
PMS AOS
BBI Light Weight Crank Pulley
AC Delete ( Including Heater Core and all lines )
Power Steering Delete ( Runs RSR PUMP )
Aasco LWFW
Porshe Sport Clutch and PP
Interior
Recaro Race Seat (x2)
Momo Corse 330mm Steering Wheels
MOMO Hub Adapter
Sparco Quick Release Hub
B&M Short Shifter
Shifter Risers ( 2 inch )
Carbon Radio Replacement Panel
Schroth Profi II -6 Hans
Fuse Panel and Plate for all interior Electrical
Sampson Racing Radio Kit with Shark Fin Antenna
Wheels and Brakes
Teflon Coated Studs with 19mm Nuts
Stock Lobster Claws ( Used as Rollers )
CCW C14 Set in Black
StopTech Sport Trophy Race Kit 6 piston ( front ) 4 piston ( rear )
Motul RBF 660 FLuid
PFC pads 08 compound( Front and Rear )
Custom Brake Ducts 2.5 inches
UPGRADES.
Guard Limited Slip Diff
Schroth Enduro Harnesses
CV Axle Boots
New Short Shifter
MOTEC CDL3
RACEKEEPER
GT3 Master Cylinder
Additional info.
Car has a new Engine. 3.4.
Installed by BlueGrass Porsche in Louisville, KY
Less then 6 DE events on new engine
New Sachs Clutch
New Gearbox and LUK flywheel
New Rotors.
Engine is a new factory crate 3.4.
Car is roughly 2,800lbs... with fuel and driver. When I bought it, the guy who built it said he estimated 375hp.
I have never dyno'd it. So without a dyno sheet its just an estimate.
* I'm sure there is more then on here. Please let me know if you have any questions.
**Serious buyers only.
***More Pictures Available upon request. I have detailed pics of all parts of the car
Just an observation. You say the engine is a 3.4 with est 375hp.
I may be wrong but that's sounds very high. Typically a 3.4 will Dynojet at 290-300rwhp.
Maybe the flash and stuff is helping. Idk
Could be confusing people.
I agree the hp claim seems a bit high.. Unless the crate motor was a dfi 3.4 from the 987.2 in there with the supporting mods? Very nice car/build though and the price seems right. GLWS
I think to be more clear, it should be 375 "crank" HP, but that is an estimate, and came from the race team that built the car. Like i stated, I have never put it on a dyno. Either way, its a new crate 3.4, which stock is 321hp. With the way the car was put together its not out of the realm to get the 375.
