Mark this thread as Unsold
FS: My '89 951 383 LSx conversion
Year: 1989
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo S
Mileage (numbers only please): 116900
Options (Please check ALL which apply): Air Conditioning, Antilock Brakes, Cruise Control, Intermittent Wipers, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Guards Red
VIN: WPOAA2950KN151096
Price (no $ sign please): $25000
Private or Dealer Listing: Private Listing
Location (Region): Midwestern
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
I built the car as a street/Time Trial car, as such it still has niceties such as air conditioning, cruise control, stereo etc. Everything on the car works, power windows, sunroof, the aforementioned A/C and so on. I went through the process of getting the car emissions inspected in the state of Colorado, its 49 state emissions compliant, not currently compliant for California although with some work it could be. The swap has received Colorado states blessing and the car gets tested as a ’02 Camaro SS. It easily passes emissions every time I’ve gone, it fast passed the last time I took it last spring.
All body panels are original and still have the VIN tags on them. Most of the paint is still original and being 25 years old is showing its age. It looks good, but has lost some of its luster. The graphics are vinyl and will easily peel off. The nose/bumper show typical rock chips and there’s a small “outtie” dent above where the throttle body sits on the hood. The car is straight, no accidents, no stories.
I’ve extensively gone through this car mechanically in the past six years and have basically rebuilt the entire car with all new parts. I’ve added/fabricated many parts that aren’t part of a normal LS swap to keep the car happy and running correctly long term such as a custom oil cooler, power steering cooler, auxiliary radiator and adding modern ABS from a Porsche Boxster.
The motor was built by Thompson Racing and has less than 3000 miles on it. I’ve been competing with NASA Time Trial Group 2, which has a power to weight limit. That’s constrained the current motor power wise, a cam swap would probably add upwards to 50 more horsepower at the wheels; as it currently sits its making 422rwhp and 410 ft lbs at the wheels.
All wear items on the car have less than 5000 miles on them. I have an extensive set of spares including body panels, wheels/tires and the like that can also be included with the sale but will be priced separately from the sale of just the car. I will not part out the car or my spare parts unless the car sells as is, whole first.
Asking price for the car is $25,000 obo.
Please look at my build threads on Rennlist and the 944 Hybrids forum:
https://rennlist.com/forums/944-turb...has-begun.html
http://944hybrids.forumotion.com/t862-it-begins
Video here on YouTube:
Engine
Thompson Motorsports Built 383 Stroker Motor, installed Summer 2014
TMS 4340 stroker crank
TMS 4340 Forged H beam rods with ARP rod bolts
RHS 232cc CNC heads with .650” Dual valvesprings
GM rockers with Comp Cams trunion upgrade
TMS LS7 lifters
Melling HP oil pump
PSI engine wiring harness
FAST 92 Intake Manifold
FAST 92 Throttle body
Custom siamesed cold air intake
Engine Power Systems 226/230 cam
Kooks 1 7/8” primary 3” collector long tube headers
Custom dual 2.5” exhaust with magnaflow muffler and tips
Custom dyno tuned by MAC Autosport
Removable 3” smog legal cats
Test pipes to replace cats
Spec stage 2 clutch
Spec aluminum lightened flywheel
QuickTime bell housing with scatter shield
Turn One power steering pump
Evans Cooling Water pump
SLP 180* thermostat
KaTech Tensioner
Ron Davis/Renegade Hybrids radiator
2004-2007 Audi S4 Auxiliary side mount radiator
Mocal oil cooler
Power steering cooler
OBD2 port with Check Engine light
Completely smog legal in 49 states, passed Smog Referee Certification in Colorado
914 drivers side headlight motor
Texas Performance Concepts (TPC)
New style uprights/set back plates and motor mounts
Brake master cylinder plate
½” cross member spacers
Oil pan and pick up tube
Oil filter relocation kit
Vehicle speed sensor kit
Fuel filter kit
Transmission
Factory 1989 Turbo S “AOR” transmission
Factory transmission cooler
Factory limited slip differential
Naturally Aspirated 5th gear
Rebuilt shift linkage and shift rod
Brakes
Porsche Boxster ABS pump/ECU
Ford Mustang hydroboost with Porsche 944 Turbo Master Cylinder
Porsche 993 Turbo “Big Red” front brake calipers with 964 Turbo front brake rotors
Porsche 944 Turbo S rear brake calipers and brake rotors
Tilton infinitely adjustable rear brake proportioning valve
Suspension
Bilstein Escort Cup Coilovers
Rebuilt/Revalved by Bilstein
450lb front 700lb rear springs
Racers Edge Camber plates
Racers Edge 2.25” front upper spring hats
Front strut bar
Rear torsion bar delete
Elephant Racing Spherical bearings
Elephant Racing rear trailing arm bearing blocks
968 M030 adjustable swaybars
Car aligned and corner weighed by Chris Cervelli
Interior
Custom welded Hanksville Hotrods rollbar
Schroth Profi 2 6 point harnesses
Momo “Competition” steering wheel with quick release
Airbags disabled, no airbag light on dash
3 gauge panel in center console with:
Autometer water temp gauge
Autometer oil temp gauge
AEM wide band Air/Fuel gauge
Sony MP3/iPod player
Recaro SPG XL seats
IO Port rollbar camera mount
All factory gauges work
A/C works, cruise control works, everything works
Sony MP3 player with iPod and USB inputs
Exterior
Factory Guards Red paint
Aerolatches hood pins (2) for hood
4 Carbon Fiber reverse louver hood vents
Fiberglass front splitter, unknown brand
968 Door handles
Curt tow hitch
All original factory matching panels with VIN stickers
Wheels/tires
OEM Porsche “MY02” 18x8” front, 18x10” rear wheels
Continental Conti sport tires
Looks like a nice car but I'm much more of a German Car guy. Although I've always had a sweet spot for a '65 Mustang fastback, GT, manual transmission of course...
Nice toy! I would love this in CA.
I have experience with CARB/BAR legal swap in CA with a 2005 Wrangler Hemi V8 swap. The following need to be on the car for CA:
1) engine newer than or same year as vehicle being swapped into
2) ECU with Check engine light and OBDII port same year as engine
3) same exhaust configuration as donor. There are some variances allowed for exhaust manifold routing, but they are looking for stock CAT system
4) fuel system routing with evap system and evap canister from donor vehicle
As long as you can demonstrate these and document the donor vehicle, you should be able to fly through your BAR referee appointment.
Good luck!
Good luck!
There's a fellow in San Diego who recently went through BAR on his LS swapped 944, his posts are on the hybrids forum.
All that needs to be done on this car is the exhaust stuff. I already had to have #1, 2 and 4 in place for smog here in Colorado.
It'll blow cleanly the way I have it set up, only difference is California has visual inspections and the current long tube headers make them unhappy...
So with a little work, this car will pass California emissions...
