Mark this thread as Unsold
1985.5 944 n/a
1985.5 944 n/a
Year: 1985
Make: Porsche
Model: 944
Cont. Porsche Models: 944
Mileage (numbers only please): 69388
Color: Slate Gray
Price (no $ sign please): $6000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
$6,000 obo
I’m a 16 year PCA member and have owned all variations of the 944 series. I’m a long time forum member and hope that I have explained the car well. Thanks for looking!
Slate Grey with Burgundy Interior, 69,800 original miles. Not a daily driver. I can confirm that since 2001 the car has been garage kept. All books, tools, air pump and two sets of keys.
Working roof, up&down no issues, power drivers seat, both seats operate as they should, all dash switches work, power mirrors (a bit of effort to get them where you want), windows and switches work, rear hatch release works, rear wiper works, heat and blower motor works in all settings, AC compressor comes on but does not blow cold. Never tested the cruise control, radiator fans work and come on at temp, headlights and all aux lighting work fine. H4 headlamps, Blaupunkt CD player, speakers and amp.
It’s largely original inside and very clean. The dash has slight cracks (photo) on the pod but the rest is very nice. No missing switches or broken plastic bits. No stains in carpet or the newer mats. Seats are in very good condition with no tears or heavy wear marks on bolsters.
The paint work is original in most areas. I found the drivers door, hood and probably the clear blended into the qtr. I’ve been inside the door and qtr and see no signs of dent repair, the underside was inspected and no damage there either. I can only assume that these were cosmetic repairs at some time. The car fax shows no accidents. The driver’s door is the only area that the paintwork shows age, I’ve tried to detail this in the photos. This is not a 10 footer by any means but it has some nicks and stone chips that you would expect. I’ve owned many cars and personally have restored some from bare metal to full disassembled cars. I’m very particular about paint, gaps etc. This is a very, very presentable car.
The drivetrain has some performance modifications; Koni adjustable front coils, rear torsion and shocks, MO30 sways F&R, short shift, cross drilled rotors F&R with performance pads, 2.5 high flow exhaust, Jon Milledge 2V camshaft, autothority big bore TB and chip (Have original), fuel regulator, . Those parts and installation dates are outlined in the service history below.
I ran a carfax on the car and the registration dates match the history I have and know of the car. I can say the car has likely not seen any winter driving in its life, as there are no tell tail signs of corrosion as I have had seen in previous cars that I have owned. The 944 areas of concern are clean, battery tray, all drains run clean.
What’s very nice about this car is that it doesn’t leak a drop, nothing. No oil, no power steering no gear oil. It’s been cared for and mechanically sound. I have the factory drip pan removed during my ownership and my garage floor is painted tan so I would definitely know. I’ve taken various day trips 100+/- trips and cruised at 80mph with no issue.
Its starts without fail, hot or cold. Runs through every gear with no issue handles great and brakes well. The trans is quite and the clutch is good. I washed and drove it this weekend
A personal inspection is welcome as is a PPI at the buyers expense. I can assist with shipping if your out of state and would not hesitate to drive it home.
PPI welcome at buyers exspense
Well over 14K in receipts of service and parts will accompany this car.
2015 – 69,850
6/15
Re finish fuchs wheels 15x7 & 15x8 – Glass beaded, refinished in silver w/ black windows and matt clear coat
New Khumo tires in factory size
Mount and Balance
Mhale Oil and Mobile Oil
Mhale Fuel Filter
New Porsche window & Blower motor relay
Remove and oil door handles, all hinges and trunk release
New gas cap
Passed emissions inspection
New hood shocks
2014 – 69,000
11/14
Belt Inspection – Removed entire cam belt and checked all rollers, WP and balance shaft belt.
Check alignment
Clean and oil K&N Filter
2011 – 68,469
7/11 Timing Belt re tension
Oil and filter service
New Interstate battery
5/2005 – 61,890
Fuel Filter
Ignition dust cover
Intake Manifold Gasket
Various vacuum hoses idle stabilizer
Re tension belt
5/2004
All fuel injectors sent to Marren for rebuild and testing
2003 – 57,848
New front and rear sway bars MO30 with Delrin Bushings
Install Koni shocks rear
2002 – 57,588
Install new throttle switch
Wheel bearings
O2 sensor
PS belt
Install new clutch slave and master
Bleed system
New thermostat switch
New fan relay
New carbon kelvar pads F&R
56,190
New plugs
Cam housing seal
Install Jon Milledge 2V performance camshaft - IS4-14 944 2V Regrind on customer 85.5 – 88 core. Power band as stock. Idle as stock. .474 cam lift (stock) intake and exhaust. Uses stock valve springs for drop in installation. 6-8 bhp improvement.
Install new drilled rotors front and rear
Broadfoot racing underdrive pully set (Have originals)
Added Turbo rear valance
Installed braided brake lines
Upgraded throttle body to big bore unit
Adjustable billet fuel regulator
Short shift kit
Authothority chip
Koni adjustable coil over shocks front
2001 – 55,118
full service
leak down test
new exhaust system 2.5 with high flow cat and muffler
1997 – 48,461
New TB and water pump service
New Clutch
1995 – 43,353
New struts front and rear
Rotors and pads
Plugs
Oil and Filter service
More pictures at:
http://s664.photobucket.com/user/JSc...?sort=3&page=1
Feel free to PM me any questions or email direct at JohnScaramella@gmail.com
