Mark this thread as Unsold
2010 Porsche Cayman S Race/Track Car
Year: 2010
Make: Porsche
Model: Cayman
Cont. Porsche Models: Race Cars
Mileage (numbers only please): 5846
Color: Green "Skoal Bandit" Livery
VIN: WP0AB2A89AU780766
Price (no $ sign please): $100000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
FACTORY SPECS INCLUDE:
•Full Roll Cage with NASCAR-style door beams painted to match body color
•Custom Window net
•SFI-spec roll bar padding
•SPARCO Pro HANS-style race seat and brackets
•Schroth 5-point quick release harness
•Remote on–board fire system with 8 nozzles
•Electrical cut-off switch
•MOMO steering wheel with adapter
•Quick release hub & roll bar hook
•Cayman Interseries Front splitter and GT3-style adjustable rear spoiler and base painted body color
•Porsche Cup Car-style hood pins and quick release rear hatch
•PSM manual cut-off switch mounted in carbon fiber center panel
•Additional external electrical fuse panel for optional accessories
•JRZ Pro adjustable remote reservoir shocks
•Fully adjustable Cayman Interseries spec front and rear sway bars with heim-joint drop links
•Hypercoil springs with helpers
•Solid spherical bearing upper shock mounting plates front and rear
•StopTech six-piston Cayman Interseries designed front calipers
•StopTech full floating front rotors with aluminum hats
•Performance Friction Cayman Interseries brake pads front and rear
•GRAND-AM GT-spec wheel studs and nuts
•Castrol SRF racing brake fluid
•Goodridge Stainless steel brake lines
•Porsche GT3 two -piece lower control arms front and rear with monoball bearings and adjustment shims
•Solid front and rear control arm bushings
•Adjustable front thrust/caster bars
•Spherical bearing tie rods with bump steer ends
•Rear toe links with bump steer adapters
•Porsche GT3 front-brake ducts
•NACA-style rear brake ducts and hoses
RACE OPTIONS INCLUDE:
•Built by Napleton Porsche, in Westmont, IL to Factory Interseries spec.
•New factory sealed engine installed 8/2013, 3.4L.- 3 hrs on engine
•Fabspeed hedders, 987.2 max flow exhaust
•Fabspeed Ecu flash
•New aluminum flywheel with clutch in 8/2013
•BMC air filters
•Shore shift kit with elevated shifter mount
•Cool suit
•Aim Pista data with smarty cam set up
•Radio system with crew headset.
•2 sets of spare BBS wheels with brand new rain tires.
•Last 2 years of service records available
•Podium finshes at Lime Rock (:57.2), (Monticello 2:30.4), NJMP thuderbolt (1:26.8)
•GTB1 in PCA, GT3 in NASA
Drop me a message and I will get you in touch with him for more history and details!
GT3 player par excellence
is engine DFI?
pls pm
pls pm
Mooty, PM Sent......for everyone else, the new motor is a Gen 2, so it DOES have DFI. It has been maintained exclusively by SpeedSport Tuning and you can view the maintenance records by request. Just PM me and I will put you in touch with the owner
Actually, I met this car at Watkins Glen. We had a minor brush-up, but never met the owner. Is the car still for sale?
Please reply my mail: fbamber@gmail.com
