Mark this thread as Unsold
Interseries Spec 2010 Porsche Cayman S
Year: 2010
Make: Porsche
Model: Cayman
Cont. Porsche Models: Cayman S
Mileage (numbers only please): 5846
Color: White
VIN: WP0AB2A89AU780766
Price (no $ sign please): $109000
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
SPECS
Year: 2010
Make: Porsche
Model: Cayman S
Engine Type: A91
Engine: 3400cc Water Cooled Flat-Six
Transmission: Six-Speed Manual
Electronics: AIM MXL Pista
FACTORY INTERSERIES SPECS
- Full Roll Cage
- Custom Window Net
- SFI-spec Roll Bar Padding
- SPARCO Pro HANS Seat
- Schroth 5-point Harness
- Remote On–Board Fire System
- Electrical Cut-Off Switch
- MOMO Steering Wheel
- Quick Release Hub & Roll Bar Hook
- Cayman Interseries Front Splitter
- GT3-style Adjustable Rear Wing
- Porsche Cup Car-Style Hood Pins
- PSM Manual Cut-Off Switch
- Additional External Electrical Fuse Panel
- JRZ Pro Adj. Remote Reservoir Shocks
- Fully Adj. Cayman Interseries Fr/Rr Sway Bars
- Hypercoil Springs w/ Helpers
- Solid Spherical Bearing Upper Shock Mounting Plates
- StopTech 6 Piston Cayman Interseries Front Calipers
- StopTech Floating Front Rotors w/ Aluminum Hats
- Performance Friction Cayman Interseries Brake Pads
- GRAND-AM GT-spec Wheel Studs and Nuts
- Castrol SRF Racing Brake Fluid
- Goodridge Stainless Steel Brake Lines
- Porsche GT3 2-Piece Lower Control Arms
- Solid Front and Rear Control Arm Bushings
- Adjustable Front Thrust/Caster Bars
- Spherical Bearing Tie Rods w/ Bump Steer Ends
- Rear Toe Links w/ Bump Steer Adapters
- Porsche GT3 Front-Brake Ducts
- NACA-Style Rear Brake Ducts and Hoses
ADDITIONAL MODIFICATIONS
- Built by Napleton Porsche, in Westmont, IL to Factory Interseries Spec.
- New Factory Sealed Engine Installed 8/2013, 3.4L.- 3 hrs on Engine.
- Fabspeed Headers, 987.2 MaxFlo exhaust.
- Fabspeed ECU flash.
- New Aluminum Flywheel with Clutch in 8/2013.
- BMC Air Filters.
- Short Shift Kit w/ Shifter Riser.
- Cool Suit.
- AIM MXL Pista Dash w/ Smarty Cam.
- Radio System with Crew Headset.
- 2 Sets of Spare BBS wheels w/ New Rain Tires.
- Last 2 years of Service Records Available.
- Podium finshes at Lime Rock (0:57.2), (Monticello 2:30.4), NJMP Thunderbolt (1:26.8).
- GTB1 in PCA, GT3 in NASA.
ADDITIONAL DETAILS
We are listing this car for one of our customers, it is a well sorted and clean example of a 2010 Porsche Cayman S that has been built to Interseries Spec and been run at local tracks. It comes with a fresh motor that has only three hours on it and a new exhaust setup. If you have any questions feel free to PM me.
