Mark this thread as Sold
1980 911 SC Sunroof Coupe
4th Gear
Year: 1980
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 140000
Options (Please check ALL which apply): Air Conditioning, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Windows, Sunroof
Color: Black
VIN: 91A0142470
Price (no $ sign please): $19900
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Professional mechanical rebuild includes:
Engine rebuild with all the proper updates, balanced and blueprinted, new rod bolts and OEM steel head studs, new chains with Carrera tensioners. Valves, guides, springs and reconditioned rockers. Air box pop-off valve. MSD ignition.
Transmission rebuild with synchros, hubs, sleeves, and guides. Short shift kit, new shift bushings. Factory limited slip. Swepco 201 gear oil. New clutch and CV joints.
Brake system rebuild with new master cylinder, new hoses, new cross drilled brake rotors, new pads and rebuilt calipers.
New wheel bearings and turbo tie rod assemblies. Lowered, bump steer kit and 4 wheel alignment. New Toyo Proxes4 tires. Front upper strut brace.
Updated AC compressor with Rennair pro cooler and safety pressure switch. R134A.
Additional updates and parts include:
H-4 headlight assemblies, turn signal and wiper switches, Carrera front oil cooler, back dated exhaust. Fire extinguisher. New fuel injectors, new rear blower motor, new front blower motor, new front condenser motor. New German windshield with seal (not-installed).
All records.
Please don't hesitate to contact me via email if you have any further questions at autowerksforsale@gmail.com.
