Mark this thread as Unsold
FS 1999 996 Carrera 2 - Tons of upgrade for street and track (HPDE)
Year: 1999
Make: Porsche
Model: 911
Cont. Porsche Models: 996
Mileage (numbers only please): 74114
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Black
Price (no $ sign please): $26500
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Stereo
Feel free to call me 6seven8-7six1-52two2
1999 Porsche 911 996 Carrera 2
$26,500
I have decided to sell my 99 996 that I have spent a fortune building over the last year. My desire was to build an awesome street car that would also be awesome on the track, and I spared few expenses doing so. As you can see from the factory options, excellent condition of the car, and maintenance records I had a great platform to begin. Unfortunately with work and family obligations, the car only saw 5 days of track time and 3 auto-x. The car drives amazing! Thanks to Tarett and Goldcrest Motorsports, the suspension on full soft is great on the street, and amazing when adjusted for the track.
Porsche Option Codes: Porsche Crest Embossed Seats (XSC), Oval Stainless Pipes (X54), Door Entrance Sills Stainless Steel with Porsche (X70), Gear Lever **** in Aluminum & Leather (X97), Handbrake lever in Aluminum & Leather (x98), Heated Seats (139,340), Locking Differential 40% (220), Traction Control (222), Automatic Limited Slip Differential (224), Automatic Climate Control (424), Rear window wiper (425), 3-Spoke steering wheel (436), Electronic Comfort Seats (437,438), Hi-Fi Package (490), Driver’s Seat Positrol and Lumbar control (537), Seat covers rear Draped Leather (939), Leather Equipment (981), Soft look leather seats (982),
Suspension - installed & Configured by Goldcrest Motorsports November 2012 @ 73,500 mi
• JRZ RS double-adjustable coil-over dampers (996 spec series)
• Eibach 2.25” springs 550/650
• Adjustable front camber plates
• Porsche GT3 adjustable front sway bar
• Tarett Adjustable End links
• Eibach adjustable rear sway bar
• Lightweight Porsche Carrera III wheels 18x8 front 10x18 rear with good Star Spec tires
• 7MM front spacers
• Porsche extended lug bolts
• Rear Strut brace
• Suspension bushings
• String Aligned and corner balanced
Brakes
• Porsche GT3 Brake cooling ducts
• Sebro slotted front rotors
• Porsche rear rotors – rebuilt when?
• Brand New Track Pads - Performance Friction PFC08 front PFC06 Rear
• Brake system Vacuum bled with Motul RBF600 brake fluid
Body
• Porsche Xenon headlights
• Porsche cup holder kit
• Porsche sport pedals
• Tequipment clear parking lights
• Alpine Radio
• Gt2 style fixed wing
Engine – 3 ring binder full of receipts from service. Significant ones below
• Motul 8100 X-cess engine oil since I’ve owned it
• Evolution Motorsports Intake
• Fabspeed Headers, Highflow cats, High flow exhaust
• Engine Tuned by TopSpeed Motorsports (topspeedtuned.com)
• Car Maintained by Goldcrest Motorsports (goldcrestmotorsports.com)
•May 2013 Service - Install replacement engine
o Full check of engine (leak down) and transmission
o Install LN Engineering IMS Bearing
o Front Main Seal
o Rear Main Seal
o Engine mounts
o Transmission mounts
o Coil packs & plugs
•Dec 2012
o Replaced Transmission Fluid and Differential fluid
•November 2012
o Suspension overhaul (see suspension section)
•Aug 2012 - Service
o Porsche 3rd center radiator
o Engine Temperature sensor
o Injectors, Changed belts, rollers, pulleys
o Coolant hoses, Coolant Level switch, oil breather hose
o Replaced plugs, tubes, and coil packs
•May 2012 Service
o Sachs Stage II Clutch Kit
o New Battery May 2012
•June 2010 Service
o Brake booster, servo, push rod
o Replaced 63mm clutch bearing
Plus many more, all stored in a 3-ring binder
I spent about 45 days talking to different experts online, by phone and in person (Jake Raby being one). I was sufficiently talked out of a reman other than Flat 6's and although I desperately wanted the maestro's engine, cant afford it right now. I happened to be at a local shop when the owner just bought a 2000 baby-blue 996 cab. The car was wrecked lightly in the front, ran well, looked well maintained, and I bought the engine on the spot (he hadn't even received it on the books yet) with a 90 day warranty. The shop did a leakdown and all the cylinders came back great. Judgmental as it may be, I figured a baby-blue cab probably had a pretty gentile life and would be a good starting point.
Fast forward, Goldcrest Motorsports checked out the engine, Leak down again and after they verified it was a good donor, I had them take it apart to do the front main seal, rear main seal, LN Engineering IMS, swap in my new clutch (may 2012) and change the coil packs and plugs. Engine happens to be stonger than the old one.
Since some of you have asked, here is a more detailed breakdown of recent services and upgrades.
5/2013
- Engine replacement $13500
- Overhaul Donor engine
o Leak down, clean and inspect all parts, LN Engineering IMS bearing, front main seal, rear main seal, coil packs, plugs, belts, fluids, transfer clutch (new from last year)
12/2012
- JRZ suspension $4200
- KSport adjustable monoball camberplates $380
- Evolution Motorsports Grand-am intake $750
- Install suspension and corner balance $950
- Replaced wheel bearing $350
- Replace engine fan and sensors $300
- Front speaker covers $180
9/2012
- Upgrade brakes
o Sebro Slotted front rotors, caliper pin & spring $560
o PFC 08 pads $580
o GT3 front brake cooling $280
o Rear wheel under body aero $160
8/2012
- Engine maintenance refresh $2223
o Serpentine Belt, Deflection Roller, Deflection Pulley, 3rd front radiator, coolant hoses, Oil breather hoses, injectors
8/2012
- Front Suspension upgrade $1685
o Gt3 front sway bar, Tarett end links, bushings, corner balanced alignment
- Coolant level switch, stabilizer mount $148
6/2012
- Carrera III lightweight wheels $1740
- Star Spec tires $1250
5/2012
- Install new Sachs Stage 2 clutch kit $2554
- New rear rotors $861
7/2010
- Installed Fabspeed headers, high flow cats, high flow exhaust $8700 parts $1575 labor
6/2010
- Brake power booster, master cylinder, brake servo, brake push rod, $1150
- Install clear marker lights around car $270 labor +$450 parts
5/2005
- 60k service at dealer $1800 (tells you how little it got driven)
Other parts:
- Eibach rear adjustable sway bar $349
- Rear carbon fiber strut brace $120
- Fabspeed exhaust tips $310
- Porsche litronic HID front headlights $3900 (according to prior owner)
- GT2 styled rear wing $1900 (according to prior owner)
- Upgraded Alpine head unit and speakers $1700 (according to prior owner)
5/2013
12/2012
9/2012
- Upgrade brakes
o PFC 08 pads $580
8/2012
8/2012
6/2012
5/2012
7/2010
6/2010
5/2005
Other parts:
I bought a 1999 M3 supposedly to be a backup DD, and it turned out to have been modded into a streetable track car. Damn thing drives me crazy with all of the CELs due to the mods, but the engine is strong.
I had a 2008 335xi, but got rid of it because the suspension and handling was just too soft. I wan't to keep a BMW as we don't have a Porsche dealer locally, and the BMW guys are willing to do alignments on my 911 track car. Nobody else locally will touch it.
Sell your M3, take my M3 in partial trade, and I'll buy your Porsche.
