Mark this thread as Unsold
944 track car
944 track car
Year: 1987
Make: Porsche
Model: 944
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 1
Color: white
VIN: WPOAA195X21N151664
Price (no $ sign please): $9995
Private or Dealer Listing: Private Listing
Location (Region): NorCal
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
ENGINE / TRANSMISSION
rebuilt with lightened crankshaft and flywheel. head gone through, new ARP rod and head bolts.
new rod and crank bearings, rings, etc..
engine oil pan is baffled
canton meca filter
Fluidyne oil cooler
Lindsey racing turbo (super 65)
55 psi fuel injectors with MAP sensor, programmed chips and programming unit
new throw out bearing, clutch fork and needle bearings.
rebuilt alternator
new water pump, radiator, hoses etc.
customer intake with filter
dual port wastegate, customer exhaust side exit
GT limited slip
new syncros, bearings
transmission cooler
SUSPENSION / BRAKES
mauual steering rack with new tie rods
rebuilt and revalved front Koni struts and rear Koni shocks
500 lbs springs
custom front lower control arms
30mm rear torsion bars
camber plates
complete Racers Edge solid and spherical bushings in rear with delrin inner / outer spring plate bushings with custom zirc nipples
solid transmission mount
customer fabricated 8 point roll cage
big red front brakes with Pagid Orange brake pads
MISC:
Kolken rear wing
Lexan rear hatch
gutted doors
Sparco Pro 2000 seat with harness
quick release Momo steering wheel
hot lap timer
customer gauges / panel
dash removed
9.5" front and 10" x 17" Fikse Wheels
fiberglass hood
fiberglass front spoiler
no expensed spared
etc...etc...etc...
Please contact Jeff @650-400-4589 OR email with questions
ANY RESONABLE OFFER ENTERTAINED
