Mark this thread as Unsold
FS: 996 Turbo X50 Coupe *Low Miles*Manual*Immaculate*Lapis Blue
Year: 2003
Make: Porsche
Model: 911
Cont. Porsche Models: 996 Turbo
Mileage (numbers only please): 29547
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof, Traction Control
Color: Lapis Blue
VIN: WP0AB29993S688598
Price (no $ sign please): $79500
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 4 Wheel Drive
Engine Type: Turbo
Stereo System: AM-FM Stereo
This car has been absolutely babied its entire life, and has been lightly and conservatively upgrade to meet the following goals:
1. Turn Key Reliability
2. GT3 Handling
3. Modern yet classic interior
Here is a list of the upgrades done since i took ownership in May 2017 at 26,000 miles.
Upgrades done by POs.
- Porsche GT2 6 Piston Calipers + 350mm Rotors
- CMS Upgraded Differential
- B&M Short Shift Kit
- Fabspeed Exhaust System w/ HJS HFC
- License Plate Light Housing (X2)
- 911 Design Key Conversion
- Bren Tuning Custom Tune for Cobb AP v3
- Cobb Access v3
- GT2 Rear Deck Lid
- Third Brake Light for GT2 Deck Lid
- Door Lock Assembly Driver Side
- Paint/Prep/Install GT2 Decklid
- "911 T" Emblem
- Carbon Fiber AC Side Vents
- Carbon Fiber Door Map Pocket Lid
- Carbon Fiber Door Pull
- Carbon Fiber Horseshoe
- Carbon Fiber Center Console
- Carbon Fiber Ignition
- Carbon Fiber Hazard Trim
- Carbon Fiber Dash Trim
- Carbon Fiber Airbag Emblem
- Carbon Fiber Non Smoker Ash Tray (Storage Box)
- Pioneer AVH 4201 NEX + Install
- Alpine PDX V9 AMP
- CSF Front Radiator
- Closed Course Motorsport adapter Hubcap for BBS E88
- BBS E88 Custom
- JRZ RS1 Pro
- JRZ Front AWD Monoball Upper Mounts
- JRZ Rear Monoball Upper Mounts
- Tarrett Front Extended Drop Link Brackets and Drop Links
- Tarrett Rear Drop Link Brackets
- 2X Rear LCA Monoball Cartriges
- 2X Rear LCA Solid Thrust Arm Bushings
- Installation Cost for Suspension + CSF Radiator
- Porsche Aero Front Lip
- Rennline Exact Fit Phone Mount
- Zunsport Front Mesh Grilles (Black)
- Sachs Performance Clutch Cover/PP - SC883082001487
- Sachs Clutch Friction Disc - SC-99711601391
- Sebro Flywheel S9-96419223931
- PO-99927007001 Bolts (2X)
- *** Clutch Pilot Bearing 11903221A
- OEM Clutch Pressure Plate Bolt M8x45mm (9X)
- OE Supplier Clutch Release Bearing Guide Tube (95011681330)
- Fichtel-Sachs - Cutch Release/Throwout Bearing: 94411608001
- OEM Flywheel Bolt: 10x24mm Flywheel to Crankshaft (9X)
- OEM Flywheel Ring Gear
- Pin Coolant Lines + Install Clutch, PP, LWFW
- Spinfab Japan BBS Hub Caps (Blue/Silver)
- 245/40/R18 Yoko Advan A052
- 315/30/R18 Yoko Advan A052
- Unique Car Care - Stage 2 Detail + Xpel on Headlights
- Dual Snorkel - Carbon Fiber Intake w/BMC High Flow filter
- Custom Recaro Sportster CS
- Recaro Sliders + Floor Mounts for Porsche 996
- Mikes Auto Body Malden - Full nose repaint
- Unique Car Care - Detail + Xpel on Full nose + Mirrors + Rear Fenders +Ceramic Pro
- Nexon Motors Hand Made Steering Wheel - Smaller Diameter/Thicker/OEM Design
- OEM Lower Control Arms + Race Alignment
- Joe Toth Carbon Fiber Canards
Car has been gently driven, and has one track day under its belt. Parked during the winter, and not exposed to rain or salt.
From the above list, you will see that the whole front end was repainted due to the clear coat peeling when replacing the clear bra. Paint was done at a highly respected bodyshop - Mikes Auto Body of Malden, and subsequently wrapped in Xpel by Unique Car Care + Ceramic Pro coating over the entire vehicle.
This is a no stories car. All necessary maintenance has been completed:
IE: Pinned coolant lines, new clutch, conservative tune.
Stock parts to be sold with car:
- Original Decklid
- Original Wheels
- Original Seats
- Original Suspension
PPI available at buyer's expense.
NOTE:
*Pictures were not enhanced or modified in anyway. Just taken with a point and shoot, and uploaded directly.
**Please do not contact me for trades or part outs, this car has to be sold to someone who appreciates it for what it is, "a modernized last hand built porsche".
Let me know if you have any questions! Thank you!
Asking $85,500.
Front:
Rear:
Engine:
Driver's Door Panel:
Interior:
Current Mileage as of 5/11/19:
Upgraded Key:
Porsche Crest Embossed on Seats:
COA:
Gorgeous turbo and appreciate all of the labor of love into this beast. I too have a fantastically built turbo and WELL above market price. Wish you the best of luck on your sale!
Those seats! So how'd you get the emblem embossed on there?
Me too have tons of $$$ on my 03 996 tt but concentrated on power and kept it stock ordinary looking 996 It's not its time yet for appreciation so just enjoying the 1100 hp bliss!. Just recently re installed the front drive shaft using a 997 unit for a less scary ride on full boost!
OP's car is beautiful!
That's the most overlooked, but yet satisfying part of the car. When i had the seats built, i knew it had to have the original grey leather - which took a long time to source, but also retain the original logo from the stock seats/options of this car. For some reason, no one could do it, and hence we had to find a shop that built custom embossing plates.
-Matt
Haha. Unfortunately, the embossing plate is with the upholster. I split the cost with him for it, and he gets to keep it.
I'm not sure how to PM, but can you put me in touch with the upholsterer?
-Matt
-Matt
