1999 M3 with S54, Full Cage, Low Miles!
20 Attachment(s)
1999 E36 M3 with S54 swap from a 2005 M3 and 5-speed manual ZF transmission. It’s an extremely quick and reliable HPDE car with the potential to make into a competitive track car. I’m the fourth owner. The second owner had the car built by Turner Motorsports, including the full cage. I had the engine swap performed at approximately 78k miles. The S54 has the VANOS completely upgraded with Besian and Dr. VANOS parts along with WPC coated bearings.
The car has a clean title, clean CarFax, no accident history, and is titled in Texas. I don’t have it registered as I trailer the vehicle. Body is in good shape, no dents, no rust, does have normal track/HPDE patina on the front end and wheel wells. The front bumper cover has some cracks where the front lip pulled away during an off, and I have a new in box aftermarket cover that will be included. The lip is secured currently, and I’ve been using as is for several months with no issues. Tires and brakes have a lot of life as the tires are scrubs that I have no heat cycles on, and brake pads and front rotors only have 4 HPDE sessions. Car needs nothing to go an enjoy track days today! DEAL: $28.5K Aerodynamics Rieger front spoiler Hard Motorsports canards Bimmerworld V3 carbon wing Mateo Motorsports diffuser Body Hard Motorsports rear polycarbonate windows Turner Motorsports under-panel Custom sunroof delete by Turner Motorsports AeroCatch hood latches Brakes Brake ducts, 3" hoses, backing plates, Turner steering rack stop Stainless steel lines (ECS) Turner brass guides Hawk DTC-60, only 4 sessions on all 4 corners New front rotors, only 4 sessions Chassis Full weld-in cage, by Turner Motorsports Turner solid motor mounts Turner solid transmission mounts AKG solid FCABs Turner solid subframe & diff mounts Drivetrain Blanton 3.64 differential Rogue Engineering differential cover AKG Race Shifter ZF 5-speed manual transmission Engine S54 swap from 2005 M3 with 82,075 miles performed at 78,000 miles Beisan Systems vanos solenoid coilpack Beisan Systems vanos seals repair kit Dr. Vanos C300 exhaust hub Dr. Vanos stage I noise reduction kit Dr. Vanos cam-bolt repair kit WPC coated rod bearings Turner Motorsports underdrive pulley RKTunes, 300 whp / 237 wtq Bimmerworld Stage 2 fuel starvation elimination kit Fluidyne radiator with Samco hoses Spal 16" fan Custom oil cooler & catch can Moroso aluminum expansion tank Motorsport 55 degree tstat Turner Motorsport custom power steering reservoir relocation Exhaust Custom section 1&2 with AA muffler Epic Motorsports stepped headers Other Custom driver floor pan by Turner; MKHA passenger floor pan Turner Motorsports pedal set 350mm Momo steering wheel with quick release Autometer oil pressure, oil temperature, water temperature gauges Longacre race mirror Fiberglass headlight intake duct Safety Hard Motorsport battery cutoff with OMP remote cable Driver window net OMP halo seat Schroth Profi II 6 Pt. harnesses Front and rear tow hooks Suspension / Wheels Turner Motorsports race camber plates Turner Motorsports sway bars (30mm adjustable front and 24mm adjustable rear) Bilstein PSS9 coilover kit Turner Motorsports wheel studs OZ Alleggerita HLT, 17” with Continental scrubs (no heat cycles on tires since purchased) Pictured, but not included AIM Solo DL and SmartyCam HD 2.1 Cool Shirt System Passenger OMP seat Recent Maintenance 4/1/2017 78,000 S54 swap 4/1/2017 78,000 WPC coated rod bearings 6/18/2017 78,209 Alternator 11/4/2017 78,319 Water pump, Motorsport t-stat, Moroso expansion tank 11/4/2017 78,319 replace oil senders 11/10/2017 78,319 Tensioner, tensioner pulley, belt 11/11/2017 78,319 Oil change 12/2/2017 78,476 brake fluid flush 1/8/2018 78,599 Flex disc, center support bearing, rogue diff mounts 4/1/2018 Transmission swap 04/12/2018 Differential seal 10/14/2018 78,971 oil change, coolant change, brake fluid reservoir gasket 12/16/2018 New battery, new oil pressure sender 12/10/2018 Speed sensor gasket, new starter 1/10/2019 Dyno, 300hp/238tq 1/12/2019 Differential overflow system 3/26/2019 79,172 brake flush, new front rotors, new DTC-60 pads (all 4) Attachment 1347164 Attachment 1347165 Attachment 1347166 Attachment 1347167 Attachment 1347168 Attachment 1347169 Attachment 1347170 Attachment 1347171 Attachment 1347172 Attachment 1347173 Attachment 1347174 Attachment 1347175 Attachment 1347176 Attachment 1347177 Attachment 1347178 Attachment 1347179 Attachment 1347180 Attachment 1347181 Attachment 1347182 Attachment 1347183 Walk around link: https://i.imgur.com/BS5vq0F.mp4 |
PM sent
PMs replied
Couple videos in action: |
Back up!
Open to reasonable offers. I've got lots of spares that can be negotiated in the deal as well, including: Second wheels set (Kosei K1) Conti scrubs Pirelli wets PFC 01 pads Used front rotors More! |
Bump it!
Wow this car must rip. What is the weight out of curiosity? Power to weight ratio must be awesome.
