Mark this thread as Unsold
1972 Porsche 911T - True, MFI, longhood HOT ROD
Year: 1972
Make: Porsche
Model: 911
Mileage (numbers only please): 500
Color: GT Silver
Price (no $ sign please): $110500
Private or Dealer Listing: Private Listing
Location (Region): South
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
Asking: $110,500 SOLD!
*UPDATE*: See newly uploaded undercarriage photos in Post #2
A freshly finished and restored Carrera RS “Touring” (M472) Tribute “Hot Rod” with period correct interior, modern touches, built on a solid, low mile, accident and rust-free, non-sunroof, true longhood chassis with original floors, doors and hood. Numbers matching engine and transmission as per Porsche Certificate of Authenticity (COA). Under 500 miles since restoration completion: Glass out paint work and complete nut and bolt build, except for the suspension which was nicely set up and was in excellent condition.
The car was originally delivered as a U.S. spec non-sunroof coupe in California in 1972, finished in Rose Red (Porsche Paint Code 33) with a Black partial leather interior. It changed hands several times and eventually ended up in Nevada. The first Nevadan owner, in the late 1990s, decided that the “Rose Red” paint had to go because it was a just little too close to the color pink. A deeper burgundy red was then chosen to replace the factory color. The next owner, a Porsche enthusiast and ER Doctor, purchased the car in 2000 and enjoyed the car “as is” for a couple years as a daily driver. Then in 2002, he decided to turn his 911T into a well sorted RS-Spec track car for occasional weekend track events, and had the car taken down to bare metal and painted Grand Prix white inside and out. Over the years the car saw limited use, and was later fitted with a 911 SC engine and transmission, to preserve the original engine MFI and transmission.
I purchased the car in 2016 along with the original engine, transmission, and nicely stored interior panels, trims and many other original parts, with the vision to build a numbers matching street car with a full period correct interior. Also, I wanted to retain some of the desirable performance modifications (the “heart of the track car”), such as the upgraded brakes, suspension, and OEM metal flares to accommodate wider rear tires.
This little “Hot Rod” 911T (-RS) is a pleasure to own and sensational drive, and it certainly draws some attention at “Cars und Kaffe”, or initiates friendly conversations at the gas station. It is also deceptively fast, smooth, handles extremely well and has a firm, taught ride, while it’s fresh interior is a wonderful “office” to get your work done.
*Please note that this build was inspired by the 1973 Carrera RS, but it is definitely not a concours replica of one. This is a super clean, carefully built, freshly refinished, and refreshed longhood 911 which was done using a combination of new and original Porsche OEM parts as well as many reproduction parts along with a few modern touches. The goal was to bring this much-loved 911T back to the street with it is numbers matching drivetrain, and retain the heart of the track car.
Please feel free to ask questions, and/or arrange a viewing/test drive.
Pre-purchase inspections are welcome and encouraged. Car is located in Las Vegas, Nevada.
More photos on request. Under-carriage photos coming soon!
Call Doug at (702) 793-0932
Or email: djngt3@gmail.com
Technical Specs:
Drivetrain:
· Refreshed 2.7L RS+ Spec (est. ~260bhp) flat six with MFI (Mechanical Fuel Injection) by Carl’s Place, Las Vegas
- 2.7L RS pistons and cylinders, RS spec valves, cylinder heads ported and polished, mechanical fuel injection upgraded to RSR spec, and the camshafts are “906” profile.
· Fresh 5-Speed transmission rebuild with Guard Limited Slip Differential by Bill Rader Motorsports, Las Vegas
· New clutch friction plate with Sachs Aluminum Sport pressure plate
· New Patrick Motorsports Lightweight Flywheel
Exterior:
· Finished in modern “GT Silver” (Porsche paint code M7Z) using PPG Paint by Devine 1 Customs, Henderson, NV
· Newly fabricated Carrera RS ducktail replica on metal lid frame and fibreglass spoiler as per the Porsche factory
· New OEM light lenses with black trim
· New JW Speaker LED headlights in H4 chrome trims with clear lenses
· Optional: Carrera RS decal package in Black
Interior:
· New MOMO Prototipo Heritage Line steering wheel (350mm)
· New reproduction period correct “Recaro S” Sports in Black Leather (made in Italy)
· New Safety belts (dated 2016)
· New Black Headliner from Lakewell in Belgium
· New Charcoal Haargarn (woven wool – OEM Spec) full carpet set from Lakewell in Belgium
· Fresh Dashboard recovering with speaker delete by George Eshaghian at Autoinno in Los Angeles, CA
· Original trims, pockets, and door panels
Chassis and Electrical:
· New fuel tank and rubber fuel lines
· Rebuilt MFI fuel filter console and Fuel Pump
· New Carrera RS thermostat modification for Oil filter console
· New Elephant Racing finned exterior hardlines and functional front oil cooler with custom ducting
· New Odyssey Battery and wiring to smuggler’s box
· Fresh under-chassis detail and wiring harness protection
· Strapped in 17” Porsche Space Saver Spare Wheel/Tire (clears front brakes), OEM Jack, and Lug Wrench
Brakes and Suspension:
· Freshly rebuilt brake calipers by PMB Performance: OEM Porsche 993 Turbo front and 993 C2 rear
· New StopTech Street Performance brake pads
· Front Rotors: Two piece drilled 332mm, Rear Rotors: OEM Carrera 3.2 drilled 290mm
· Bilstein Sport Shocks Front/Rear
· HD Torsion bars Front/ Rear
· Weltmeister HD Sway bars Front/Rear
· Custom ride height and Alignment by Carl’s Place, Las Vegas
Wheels and Tires
· New Tires Michelin PS2 (Porsche N3 spec) in sizes: Front 225/45R17, Rear 255/40R17
· RSR style Rota Fox 17” wheel set (Note: 17” wheels are necessary to clear the 993 Turbo brake upgrade)
Place saver for undercarriage photos......
Ah, I know you are excited to see some undercarriage photos.....here you go! Enjoy!
man, it's gorgeous
WAY TOO HOT.
Seriously amazing car man. GLWS
WOW, thank you so much for the kind words everyone! It has been a labor of love for sure.....the modern GT Silver paintwork makes it pop!
Wow, gorgeous! Would look great next to my GT Silver Boxster.
Just wow! Just bought a Carrera T to go with the RS yesterday...this made me think of going in another direction!!
Very nice car. I know firsthand how long and sometimes painful these nut and bolt restos can go, and you did it right. GLWS and very nice price–a bargain for the buyer.
Well, the oldies do give you a different perspective and appreciation......I like to have at least one air-cooled and one water-cooled "in stock" for my driving pleasure.
