Mark this thread as Unsold
Lamborghini Gallardo Superleggera Lp570-4 TT
Year: 2011
Make: Lamborghini
Model: Gallardo
Mileage (numbers only please): 10924
Color: White
Price (no $ sign please): $215500
Private or Dealer Listing: Private Listing
Location (Region): Texas
Body Style: Coupe
Transmission Type: Tiptronic
2 or 4 Wheel Drive?: 4 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
Up for sale in my personal 2011 Lamborghini Gallardo Superleggera LP-570-4 Twin Turbo. Mileage as described above. Build has approximately 1,000 miles on it. An upgraded clutch was installed last week. I have all service records in hand. Contact me at 4697194136 or saleencollector@gmail.com with any questions. Thanks
Dallas Performance – Stage 3 – 2009-2014 Gallardo LP-560/570 Twin Turbo System with MoTeC ECU Upgrade. 1000whp on 93octane. 1250+whp with 105 octane fuel.
Twin Turbo System:
Twin Billet Ball Bearing Precision Turbos (Stage 3)
Twin Billet Tial V-band Wastegate
Twin Billet Tial Blow Off Valves
Race Core, Air to Water with Custom Fabricated Tanks and Fittings High volume Intercooler Pump
Oversized 12AN Intercooler Hoses and AN Fittings
Custom Fabricated Stainless Steel Turbo Hot Side System
Custom Fabricated Stainless Steel Exhaust /Discharge System
Custom Fabricated Stainless Steel Charge Pipes with BOV
Large Heat Exchanger for Air to Water core
Large Water/Ice tank with Billet 6.0" DP Filler Lid
Black Silicone Couplers
Stainless Steel T-bolt Clamps
4.0" Air Inlet Piping and High Flow Air Filters
SS Braided Oil Feed and Return Hoses with AN fittings for Turbo Oil System
Black Texture Powdercoated Finish Standard on all Cold Side Components Ceramic Coating on Exhaust Components Standard with High Temp Heat Wrapping
Engine and Boost Management:
MoTeC ECU
MoTeC Boost control
MAP Pressure Transducer
EMAP Pressure Transducer
MoTeC 4 Position MAP Switch Included Fast Response Charge Air Temp Sensor Twin Wideband Oxygen Sensors MilSpec Wiring Harness
Fuel System:
Custom Billet Hard Anodized Fuel Rails
10 additional high impedance injectors
Billet Fuel Hanger with High Flow Fuel Pumps
Billet Fuel Pressure Regulator with 1:1 Reference for Boost Application Stainless Steel Braided Fuel Lines and AN Fuel Fittings
Forged Engine Upgrades:
Custom Steel Cylinder Sleeves and Machine work
Custom Carrillo Connecting Rods with High Strength Rod Bolts
Custom Forged Piston Set with Moly Skirt Coatings
Upgraded H-13 Heavy Wall Wrist Pins
Upgraded Tool Steel Piston Ring Pack
Lamborghini Gallardo Engine Main Bearings
Lamborghini Gallardo Engine Connecting Rod Bearings
Lamborghini Gallardo Engine Thrust Bearings
Lamborghini Gallardo Front and Rear Main Seal
Lamborghini Gallardo Gasket kit including Head Gaskets
Lamborghini Gallardo Engine Main Bolts
Custom ARP Gallardo Engine Head Stud Upgrade
Machine Work and assembly of engine short block
Disassemble and Reassemble Lamborghini Gallardo Cylinder Heads
Stage 3 Porting of Cylinder Heads. Intake/Exhaust Ports
Anti-detonation porting and polishing of combustion chambers
Competition Valve Job on Cylinder Heads and Surface Mill
Complete engine Engine Break In Oil and Oil Filter
Engine Coolant and other fluids including shop supplies
Fully Installed and Tuned by Dallas Performance LLC
Upgrade to BILLET Transfer Case gearing - quiet helical gears.
HRE Wheels- 3 piece with multi finish - 19x8.5 front 19x11 rears
Toyo R888 tire set with mounting and balancing
Custom lowering spring package
Twin Turbo System:
MoTeC ECU
MoTeC Boost control
Fuel System:
