Mark this thread as Sold
Dealer Inventory 1988 Porsche Carrera
Premium Dealer
Year: 1988
Make: Porsche
Model: 911
Mileage (numbers only please): 52700
Color: White
VIN: WP0AB0912JS120432
Price (no $ sign please): $75900
Private or Dealer Listing: Dealer Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
White/Red with 52,700 miles. A nicer one does not exist.
The following was done by Orbit Racing within the last year:
Complete undercarriage restoration. All parts removed, either replaced, restored, or cleaned/serviced and reused. Bottom of the car was dry-ice blasted then repainted.
Gearbox was completely taken apart, all synchros replaced, new pinion shaft four point bearing, new differential bearings, all gaskets and seals. All set-ups dimensions were checked and set to factory specification with Porsche factory tools.
Engine received a major service, plugs, valve adjustment, belts, check head studs. Intake was removed and fuel lines on engine were replaced.
Front suspension was stripped to bare metal, epoxy primer, then power coated black. All new bushing, hardware replaced, new front strut inserts, new torsion bars.
rear suspension replated, new torsion bar bushings, new torsion bars
rear suspension, new wheel bearing in trailing arms, new bushing in trailing arms.
new oil lines, new oil thermostat, new rear shocks.
front and rear bumpers completely taken apart and repainted. Assembled with new rubber and new hardware .
New front strut inserts, new front rotors, front wheel bearing replaced, new turbo tie-rods.
For more info PM, email rw@atlantismotorgroup.com or call 800-935-9590
www.atlantismotorgroup.com
