Mark this thread as Unsold
1995 Porsche C4 993
SOLD: 1995 Porsche C4 993
Year: 1995
Make: Porsche
Model: 911
Mileage (numbers only please): 78400
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Black
VIN: WP0AA2997SS324133
Price (no $ sign please): $38000
Private or Dealer Listing: Private Listing
Location (Region): West
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 4 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
All fluids (brakes, steering, oil)--everything is up to date and in check.
Performance updates--all receipts for everything--30k,60k tunes.
OPTIONS:
Vehicle Identification No. WP0AA2997SS324133
Model Designation CARR.4 COUP
Model 1995
Order Type 993130
Engine code M64.07
Transmission code G64.20
I218
I233
I323
I434
I694
I912
IX31
IXC8
M032 Touring suspension
M058 Impact absorbers, front and rear
M130 Control and indications in English lettering
M197 Stronger battery
M220 Locking differential 40 %
M224 Automatic limited slip differential
M288 Headlamp washer
M335 Automatic seat belt, 3-point,
rear
M339 All-wheel drive
M398 Cup wheel, 17-inch
M437 Comfort seat, left,
electrically adjustable
M438 Comfort seat, right,
M441 Radio preparation
M445 Silver wheel centres with
full-colour Porsche Crest
M454 Automatic speed control
M455 Anti-theft device for wheels
M480 6-speed manual transmission
M484 Version for USA
M490 Sound package
M530 Anti-drive-off feature -96
Anti-drive-off feature 433 MHz 97-
M534 Theft security system
M544 Tank of 75 litres
M553 Version for USA, Canada
M562 Airbag, driver's side and front passenger's side
M566 Front fog lights, white
M567 Windscreen tinted, upper part
darker coloured
M573 Air conditioner
M576 Without rear fog lamp
M599 Roof cover molding
M602 Raised stop lamp
M650 Electrical sliding roof
M651 Electric window opener
M657 Power assisted steering
M685 Rear seats, split
M975 Luggage compartment lining
with velour carpet
Performance Parts/Upgrades--all receipts in hand
LWF, ECU upgrade (Rennsport) Mille Miglia exhaust, Fabspeed Air Box, Hargett Precision Lowers, BMC Filter, white gauges, silver emergency brake and shifter/pedals ,MO30's, Bilstein HD's, lowered between RS and Sport, sway bar, KLA strut bar, Gert Protection Bar, Immobilizer, Viper alarm system
The Pioneer stereo---head/single CD, speakers, and an amp--nothing to write home about but have all the documentation on it--I pulled the CD changer years ago.
Here was my 60k tune. You name it, I had it done 18,000 miles ago. I spent around $6k or so this trip to the shop. I just had the oil changed this past week, rear seal replaced, and the AC Head replaced. AC works great.
ALL DONE DURING 60k tune up
(Note: * denotes parts supplied by me)
1. * Suspension upgrade:
a. 4 X Bilstein HD shocks (with 30mm extra threads)
b. 4 X ROW M030 Springs
c. Front 22mm M030 Sway Bar
d. Rear 20mm M030 Sway Bar
e. Rear Drop Links
f. Front Drop Links
g. KLA Strut brace install
2. * Change spark plug wires-Beru
3. * Change air inject check valve (SAI check valve)
4. * Change both cabin air/pollen filters
5. * Change the engine air filter
6. * Change all 12 spark plugs (yea, esp. # 12 that, I know, is a PITA)
7. * Change both distributor caps
8. * Change both distributor rotors
9. * Change fuel filter
10. * Change engine oil (I will supply 10Q Mobil 1 - 15W50)
11. * Change large oil filter
12. * Change small oil filter
13. * Change A/C compressor drive belt
14. * Change Alternator drive belt (inner)
15. * Change Alternator drive belt (outer)
16. * Change power steering belt
17. * change ignition coil wire
18. Change manual transmission fluid. REDLINE
19. Bleed/flush the clutch hydraulic system
20. Bleed the brakes
Note The brake system was completely flushed less than 7 months ago so the
(ATE super blue)
21. Please perform all the (remaining) normal checks, lubrications etc. as
specified in the
60k service interval. In particular, please re-lubricate/check tolerances of
the manual
transmission gear-shift linkages/bushings etc.
22. Remove and Clean ISV
23. Replace front hood shocks
24. Belt Tension Indicator rebuilt
25. Ignition Coil replaced
24. Distributor Rebuild
38,000.00
Buyer responsible for shipping and any PPI. No checks or out of the country shipping. Wire transfer for funds. If PayPal, buyer pays fees. Includes all receipts/performance upgrades---all documentation.
Beyond reasonable!!! http://www.motorgems.com/?p=1434
