Mark this thread as Sold
Dealer Inventory 2006 "Twin-charged" Ariel Atom 2
Premium Dealer
Year: 2006
Make: Porsche
Model: 0
Mileage (numbers only please): 5000
Color: Black
VIN: A2RTE2SBK6A000080
Price (no $ sign please): $79500
Private or Dealer Listing: Dealer Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM Radio
“In 2005 Track and Race Car magazine published the results of a comprehensive test of a range of cars, from the Porsche 911 Carrera S, Ford GT, BMW M5 to the Caterham CSR 260. The supercharged Ariel Atom 2 won the 0–161–0 km/h (0–100–0 mph) test by a clear margin at 10.88 seconds, ahead of the Caterham CSR 260 (11.41) and the Ford GT in fourth (13.17). The Sunday Times measured the time taken for the Atom to accelerate from 0 to 97 km/h (60 mph) at 2.89 seconds, making it the world’s third-fastest accelerating production car then available, after the Bugatti Veyron’s 2.46 seconds and the Ultima GTR at 2.6 seconds.”
The following video from the BBC’s show Top Gear, featured Jeremy Clarkson reviewing one of the Supercharged Ariel Atom 2’s and instantly sprung the car to the forefront of super car enthusiasts wish lists the world over:
Other reviews and accolades can be found here:
https://www.caranddriver.com/feature...7-ariel-atom-2
https://www.motortrend.com/news/2007-ariel-atom-2/
This particular example is a 2006 Ariel Atom 2 and is 1 of 3 ever to feature the DDMWorks “Twin-Charged” kit (Supercharged AND Turbocharged) capable of 700hp! The build on this car has been meticulous to say the least and was undertaken with an absolutely no expenses spared approach. (over $100k invested) Recently, the Atom was tuned to just under 400 HP at the rear wheels which ensures the perfect combination of useable power and a pure adrenaline rush every time it is driven.
In preparation for its sale, the car has been thoroughly gone through with even the most minute details such as decals and wiring loom having been replaced as needed. Additionally, fresh Lexan side panels were recently installed and carbon fiber fenders (not pictured) will also be included with the vehicle. Having only covered approximately 5000 miles since new and needing nothing, this car is ready to be thoroughly enjoyed both on & off the track.
Below is the most recent dyno sheet showing Max Power/Torque @ 393 HP / 329 FT-LB
DynoSheetAtom
The build details and options are as follows:
Engine
- GM 2.0L Ecotec Engine Stage 3
- DOHC With sequential fuel injection
- Bore 86mm x Stroke 86mm w/ 9.5:1 Compression
- Upgraded Fuel System w /Siemens 100# fuel injectors
- Boost preference fuel adjustment system
- Upgraded ZZP High Voltage Coilpacks
- Tuned to 23psi yielding 392.6whp, fuel and ignition capable of 500whp with stronger clutch
- NGK Iridium Plugs
- Oil Accumulator Option
- Aluminum 3-core Race Radiator Upgrade
- Aluminum 2-core Supercharger Heat exchanger upgrade w/ second cooling fan
- Skunkwurx Duo Carbon Front Wing
- Skunkwurx Duo Carbon Rear Wing
- Custom Adjustable Rear Wing Mount
- Front Tow Hook/Rear Tow hook
- Autobahn Mirror
- Lightweight Sector 111 Ethos 17×9 Rear Wheels w/ Toyo 275/35R/17 R888 Tires
- Lightweight Sector 111 Ethos 15×7 Front Wheels w/ Toyo 205/50R/15 R888 Tires
- Upgraded Chromoly Wheel Bearings/Races
- Koni 3012 Dual Adjustable Coilover Shocks
- Upgraded Chromoly Steering Rod Ends
- Atom 3 Front Wishbone Suspension (upgraded A-Arms with Race Chromoly Rod Ends, eliminates Atom 2 adjustable thimble flaws)
- Upgraded Chromoly Rod-End Spacers from TMI
- Upgraded TMI Race Ball joints (front/rear)
- Wilwood 4x 35.1mm Dynalite Calipers
- Zinc Coated Wilwood two-piece vented & slotted rotors 279.4×20.6mm
- Parker Parking Brake
- Stainless Braid Lines
- Tilton Fluid Reservoir upgrade
- Wilwood Cockpit Mounted Brake Bias Adjustment
- Motul RBF 660 Brake Fluid
- Wilwood Polymatrix A pads (most aggressive)
- HKS EVC6 Master Boost Controller w/ Scramble Boost
- Turbosmart MBC for Turbo/Supercharger transition control/dampening
- Dash 2 Pro system w/ GPS License
- Skunkwurx Race Dash – Complete Upgrade for Ariel Atom from SPA Dash to Carbon Fiber Digital Dash with LED Buttons
- GPS Data Logging License
- RFid Key/Immobiliser Unit
- AEM Water/Meth Injection System with adjustable threshold and 2gal center mounted reservoir
- Momo R1960/32S Steering Wheel
- Carbon Fiber Center Console
- Atom 3 Windshield
- 12v Aux Outlet
- Passenger Footrest Option
- 2” Upgraded SABelt 5pt harnesses (Driver and Passenger)
- Recaro OEM Branded (Ariel) Leather Race Seats
- Street Lighting Package w/ Low/High Beam
- SCCA/NASA Approved Full-containment Rollbar System
- SCCA/NASA Approved Battery Cutoff
- SCCA/NASA Approved Decal Package
Premium Dealer
Talk about an incredible driving experience.....WOW!
