ATC or Sundowner 18' open trailer anyone?
I'm looking to buy an aluminum open trailer to haul my GT3RS. Being in California I'm not finding any used Trailex trailers which I think would be my first choice.
Anyone have any experience with either ATC or Sundowner brand trailers? They are about the only ones I can find within a 100 mile radius of my location. The Sundowner is local to me and appears to of very nice quality construction but what worries me is that it does not have a dove tail like the ATC trailer. Both have 7' ramps. The Sundowner has a removable fender, the ATC does not but I've measured and the door will open with no problem, which sounds like a better deal since I would not need to fool with removing it to exit the car. Both have 3500lb axles with electric brakes and 15" wheels.
Should I get a stone guard?
I've got the ATC open and formerly had a Trailex 8045. Personally I prefer the ATC. Fully welded construction, has the solid deck and lots of small nice features such as steps in front/rear of the fenders. The positioning of the D rings wasn't optimal so I got some track from Mac's and had it welded to the deck. Works great. Weighs a few hundred more than the Trailex but overall I think a more robust product for equivalent price.
My friend has a Trailex and it just clears.
Yes I have front end lift and it comes with 7' ramps so I think it should load OK. I don't think the Sundowner without the beavertail would work for this car.
I compared both brands and chose sundowner. I think for somebody with an unlimited budget, ATC is probably the better route. I'm not convinced they are as well-made as the sundowner at the same price points. Meaning, I had to really load up the ATC to get to sundowners base level of quality in terms of materials used. This was for an enclosed trailer so different comparison, but I suspect same with open. Sundowner used heavier aluminum skin, same size spread axles, larger wheels, aluminum (not rubber) flooring, heavier D rings, list goes on. They have a long history with horses. Newer to cars. Not ATC bashing, I think they are the best, if you can afford to pay extra for some of these things.
Originally Posted by Matt Romanowski
I saw one at Palmer and it looked very nice, though the owner (you?) was having trouble getting one of the axles to lock back into place. I thought it was probably from flexing, but didn't see them before they left.
Rennlist Hoonigan
which cost no drachmas
So yes there are four safety latches that need to pop into place. The problem is if the trailer in on uneven ground i.e. Dirt at Palmer once the first one latches the winch stops. This is a built in safety mechanism so then you have to move the trailer until it's level and try to raise it again.
