My new 24ft sundowner
As I previously reported, love this brand, which is new to me. Think they made their mark with horses but have started making car haulers. Everything custom to order, in house. 100% made in USA. All aluminum, .50 gauge skins, extruded floors, 16 wheels/tires, spread axle, led lighting etc. Gonna go on it's first trip to California for Luft next week.
For anyone looking at ATC, featherlite, intech etc, I would recommend taking a close look at this brand. I found the "bones" quality to be same or higher on this brand than some of those others. Maybe not as "pretty" cosmetically, but I'm super happy with build quality.
thanks
yes, my last white trailer was always pretty nasty and tough to clean. hoping the coating will help a bit with power washing easier, but we will see...
Looks nice. But I have to question the driver's side escape door design. Its not low or wide enough and needs inside mods to be (partially) useful. In regards to that a comparison to ATC or Intech doesn't seem fair since they have, what I would say, listened to their customers and created a useful and functional design.
I agree that the escape door on ATC is the best. No question about that. But across a lot of other dimensions, they seemed to put more emphasis on cosmetic than on structural, when comparing apples to apples and dollars to dollars. Extruded aluminum floors, heavier duty d rings, e-/airline tracking, upgraded 16 inch wheels, 50 gauge aluminum skin instead of 30. These things are all standard with sundowner. There were a couple things I liked better with ATC. Like the escape door. But I certainly don't think that makes the comparison unfair. For 19K, I feel that I got a trailer with the bones that would've cost 25k+ in the ATC line
Trucker
The trailer looks really nice. Congratulations.
A few weeks ago I placed an order for a 28' 4926 FL. My previous was the same. I like 100% aluminum, no plastics, wood, ...
I did see this brand and they appear very nice, with horsey DNA, but I could not find one to go and see in person. Did you pick it up in TX? DD your dealer have any in stock?
What's the length? 24'?
It's a 24 ft. No relationship with the dealer other than satisfied customer. P.m. me if you want info. Loading up to tow to Luft next week.
Trucker
^Thanks. Too late for me as I have one coming.
I do like the looks of Sundowner with the cladding on the side and the spread axle. That spread axle will get you a nicer ride with the longer wheel base and load stability, but you will be scrubbing those tires making tight turns. Thank you.
I'm just sharing my experience. I easily open the door walk out of the car and walk out of the escape door. Perhaps this is not the case for all cars or different positioning in the trailer, but it works great for me and I tried it before I purchased.
Do I wish it had the huge ATC escape door? I absolutely do. Do I prefer the extruded aluminum flooring, thicker aluminum skin, larger wheels and tires, larger d rings, e/airline tracking and other structural upgrades as standard? Personally I do. To each their own and your mileage may vary. I'm not a sundowner dealer. Just a happy customer. ATC offers all of these things but they were all options and I fatigued on the thousand paper cuts of models, options ordering etc. The cheapest sundowner to the most expensive one use all the same heavy duty structural components and I liked that. Pick a size and configuration. Done.
Trucker
Have you weighed your trailer?
For reference, we own around 250 Great Dane 53' box and 75 Western spread axles flatties along with 100 Freightliner Cascadias and 25 Kenworth W900 reward trucks. So this stuff is my business.
Your post has perked my interest. Sundowner is actually a good trailer maker. I called them up and got some information. They run 7' height versus the 6'6" on Featherlite and the extruded bottom end adds more weight. They told me at 24' the Xtra weighs 4,300 lbs whereas the Featherlite weighs 3,350! At 28' the weight difference is 1,100 lbs Your 24' should have also come with 16" aluminum wheels and 5,200 lb axles
