Escape Door
Escape Door , WITH REMOVABLE FENDER
Looking to upgrade my open flatbed for an enclosed trailer. I have been planning on getting a trailer with the the full side escape door and it is about a $2k option. The more options I keep adding :-) I'm now questioning if that is really a must have. I think it is so I wouldn't have to winch every time but maybe that isn't that big of a deal (btw, I'm not climbing out of the window). Wanted to check and see what the brain trust has to say as I need to make a decision in the next 2 weeks.
Thanks for the input
If you do get an escape door on an enclosed trailer, make sure you get the newer one I came up with in 2104. Big Escape Door with REMOVABLE FENDER, the old style escape doors that the fender does not come out are pretty useless, too high to clear over the fender ( usually a 14" minimum threshold height ). The old school doors had to build " ramp overs" to raise the car inside. For the $2,000 it costs to do it right it is worth it in ease of use, and resale value. I did a track day and left a borrowed hekmet in the car, was able to retrieve it from a strapped down car in a few minutes, would have been 45 minutes to an hour to unstrap the car, roll it out, then tie it back down. Then just after realized I had left my wallet in the glovebox, best thing ever !
Jump box works fine with my wi-fi-remote winch.
I have a stub wall in my trailer. My winch was mounted to the top of the stub wall and triangulated with a turnbuckle mounted to a strip of E-Track bolted to the trailer floor against the front trailer wall.
When I sold my Elise and got a Cayman, I noticed the tow ring on the Lotus was on-center and the tow ring on the Cayman was 12" right of center.
I mounted a 5' parallel-style E-Track to the top of my stub wall. Then I mounted my winch to the backside of a shorter piece of vertical E-Track. Slapped them together face-to-face. Sourced a couple of E-track clips with enough reach to lock the two tracks together. One clip goes on each side of the winch.
This allows me to move the winch right or left in 4" increments. Easy to move the turnbuckle to match.
Now I can winch essentially any car with a tow ring, one hand on the remote, and the other on the steering wheel.
buzzyn (02-06-2023)
If you do get an escape door on an enclosed trailer, make sure you get the newer one I came up with in 2014. Big Escape Door with REMOVABLE FENDER, the old style escape doors that the fender does not come out are pretty useless, too high to clear over the fender ( usually a 14" minimum threshold height ). The old school doors had to build " ramp overs" to raise the car inside. For the $2,000 it costs to do it right it is worth it in ease of use, and resale value. I did a track day and left a borrowed helmet in the car, was able to retrieve it from a strapped down car in a few minutes, would have been 45 minutes to an hour to unstrap the car, roll it out, then tie it back down. Then just after realized I had left my wallet in the glovebox, best thing ever !
And, yeah, forgetting a helmet in the car is a lot easier to deal with. Especially if the car is an Elise and the helmet is closed-face. A closed-face helmet will not fit through the window of an Elise with a hardtop.
Shorty story, get the escape door. It’s just better.
