Pulling a 24’ Featherlight
Old 07-14-2019, 10:42 PM
Max1865
Max1865's Avatar
Default Pulling a 24’ Featherlight
Recently bought a 24’ Featherlight to replace a Trailex 8045. Tow vehicle is a Yukon Denali. Pulling the Featherlight for short hauls on two lane highways is fine but on freeways or speeds above 55mph things are not comfortable. Do I need a 3/4 ton or a 1ton dually?
Old 07-14-2019, 11:14 PM
RossP
RossP's Avatar
What year denali do you have?
skxf430
skxf430's Avatar
A bigger truck is always more comforting than a SUV, but it is still doable. Make sure your tongue weight is correct and you car is positioned correctly. Also, a weight distribution hitch changes things dramatically. You can try these couple of things before buying a truck. I personally like the security of a bigger truck.
Old 07-14-2019, 11:35 PM
cienegavista
cienegavista's Avatar
I pull my 24 ATC with my 2002 avalanche, longer than your tow rig and heavier but same drive-train. I can pull at 75 easy, Anderson sway/weight distribution hitch. The lanche is heavy, 6000 lbs with driver which helps stability, the Denail offers a much shorter wheelbase which could get sketchy. Longer wheelbase, heavier tow vehicle will do it, it does not have to be a 3/4 ton but you need to have appropriate tongue weight and monitor how much gross weight you are pulling. If that is an issue then 3/4 ton tow.
mc
Old 07-15-2019, 09:39 AM
Max1865
Max1865's Avatar
2011
Old 07-15-2019, 10:03 AM
ohenryinatlanta
ohenryinatlanta's Avatar
tahoe / denali is too short and too softely sprung
you don't need a dually but something with a longer wheel base will definitely help
i tow my 24ft featherlite with an excursion
Old 07-15-2019, 11:07 AM
RossP
RossP's Avatar
I am not sure on the 2011, but as others have said, longer wheel bases are generally better for bigger trailers.
I have a 2017 Yukon XL Denali and it is actually a pretty decent tow vehicle. It is only rated to to 8k. but it does have the 6.2 V8, integrated trailer brake controller, air leveling rear suspension, and a electronic locking rear diff.
Old 07-16-2019, 09:06 AM
Max1865
Max1865's Avatar
Thanks for all the suggestions and comments. Yesterday I went and talked with the man who worked on my Trailex and he suggested putting E rated tires on the Denali. So going to get a new set of tires!
Old 07-16-2019, 08:39 PM
skxf430
skxf430's Avatar
I would think a WD hitch would have more of an affect than E rated tires on the Denali but let us know what happens.
My WD hitch made my drive so much easier and less stressful.
Old 07-16-2019, 09:40 PM
ExMB
ExMB's Avatar
Received 1,317 Likes on 800 Posts
Those E-rated tires are not going to help improve your towing experience as posted by you. RL membership has no skin in the game other than to help you.
As stated your wheel base is short.
A WD hitch with sway control would do wonders.
Etc
Old 07-16-2019, 09:47 PM
Max1865
Max1865's Avatar
Etc
I agree with you and all the others, wheel base is to short. But hoping the tires will help enough for short hauls and use the RV for long hauls.
Old 07-16-2019, 10:17 PM
Gadsby
Gadsby's Avatar
Gt3 in 24’ featherlight with gl550 or the denali xl, super smooth and no issues at all.
Old 08-10-2019, 08:30 PM
PopsRacer
PopsRacer's Avatar
I have towed a 24’ Featherlite trailer with a 2007 Yukon Denali XL for several years without a problem. Along the way I added additional air bags, load hauling springs, and eventually a 6.2 crate motor with an Edelbrock supercharger. I would check your loading/tongue weight.
I finally upgraded to a 3500HD crew cab Denali dually, with an auxiliary fuel tank in the 8’ bed,a few years back and only wish I had done so earlier. It just makes everything easier. Just with everything else, it’s a slippery slope when upgrading. Good luck!
Quick Reply: Pulling a 24’ Featherlight
