Upgrading used enclosed trailer - what can't be done
I tried to make the title useful. I'm in the market for an enclosed trailer and am very open to buying used. What I want to understand is what features can't or are exceedingly expensive to add to an existing trailer. I'm going to assume most things can be added relatively easily (cabinets, etc) and so am focusing on the can't be done.
Specifically
Thanks ahead of time.
Specifically
- escape doors
- electrical
- generator area
- AC - I am guessing if there is a ceiling vent then its relatively easy
Rennlist Hoonigan
which cost no drachmas
I think it would depend on the interior finish of the trailer. If no removal of wall coverings is necessary, then electrical is easy to add (drilling holes, running wire, etc). Doing the escape door and generator compartment would most likely be cost prohibitive unless you are talking a very expensive trailer. AC is not a big deal on most any trailer with a good roof.
Most AC units ,, use the same size hole as the standard roof vents,, its all the mounting that makes it look big..
Make sure the trailer is a CAR hauler not a toy hauler, the frame on a car hauler is heavier and the flooring is thicker.
I've helped add a second layer of plywood to a couple to make the floor more ridged.
Have the axles checked,, I am not a fan of the torsion axles, had 2 different ones give up and
stick us by the side of the road for a day or two.. Higher weight rating is good, 8 lug have duty axles if you
need to replace them,, its a couple hundred extra but their larger bearings reduce rolling load and
last about 10x the miles of the 2500's that come on a lot of trailers..
Aluminum frame walled trailers are lighter, but if you use it in cold weather the ribs will sweat,
so FRP sheeting is better on the inside so it won't rot.
Make sure the trailer can breath, and not let vermin in.. you should have 2 vents front and rear
to allow some air flow when traveling. The vents are usually at the upper corners and about 4" in
diameter with some airflow covers on them.
Trailers with a fuel door are a bonus.. It's handy for opening to get some extra ventilation.
if you add a window/hatch to a trailer you'll need to open the interior wall, because full need to
add the framing for the window, don't let some trailer shop hack one in, they will just cut the
hole bolt it in and it WILL leak.
I like a good generator box on the tongue of the trailer,, locking sturdy and its outside the trailer
so at the track you don't have to listen to it as much. don't over buy the gen the 2000 Honda is
bulletproof and will run lighting and a small TV/Microwave etc.... The Honda is also quiet for the
times your just hanging out..
With the generator setup on the tongue then that would be a relatively simple install since running the wire into the trailer would be the only part that is modifying walls/structure.
Thanks for feedback.
WRONGLY ACCUSED!
Received 3,241 Likes
I think just like a race car it is cheaper to buy something with most of what you want versus having the work done yourself. It just takes more time to wait for the right deal to show up.
I found a 27 foot trailer that had all the basics I wanted, added a couple of cabinets and other small easy to do myself items, and bought a Honda inverter which I just lug out (30 seconds) instead of having a sliding drawer.
Airconditioning is nice but I tell you I have a large fan and when I sit in front of it for 1 minute I am good. Airconditioning is nice but it draws a decent amount of power and is another thing to maintain. My personal preference is a $40 big harbor freight fan strapped to the side of my trailer.
You can also a post a WTB here on RL and see what shows up.
I have no use for AC in my trailer. Reality is that it is body shock going into and out of trailer with AC blasting. Fan with air movement is so much nicer. I am done with generators as solar is so much better, and always there. Battery bank always topped off. Be aware that if you buy an enclosed trailer with exposed studs then you also have exposed exterior skin. Stuff bumping around inside will leave welts outside, and sweating inside can be a problem.
Just post your ideas. Rennlist braintrust will have an answer. Maybe crazy answer, but still answer.
The Penguin King
