Going solar with trailer.
Finally had time (under pressure too) to get these installed. Bought them a year ago. 544 watts of solar on the roof.
Prep with random orbit 11" with maroon Scotch Brite to get the crusties off. I followed this with battery leaf blower and 3-4 passes with denatured alcohol with white rags. https://cimg1.ibsrv.net/gimg/rennlis...4ed9510352.jpg Panels are last generation but better for my use. At home trailer will be partly in the shade and these panels are OK with that. Batteries in pit will still get topped off and maintained. Adhesive on back is evil sticky good. Where you put them is where they will stay. https://cimg5.ibsrv.net/gimg/rennlis...1f17462149.jpg Penetrations through roof are adhered/caulked with Sikaflex and the little wire housings are supplemented with 2 stainless screws each. May or may not caulk the perimeter of the panels. 60 amp charge controller gets wired in soon and 300 ah of batteries already in the pit. 2000 watt pure sine inverter already installed but need to remove its GFCI and install those at each outlet. GFCI trips instantly when connected directly to trailer wiring. Goal is to have power for new 12 volt reef all the time and batteries always at perfect charge. Reef needs to run around the clock and still have plenty of juice in pitt after to run winch and trailer landing gear. More pics as the installation progresses. Got a bit of sun on my arms doing this today. But all good. |
That is very cool, can't wait to see how it turns out.
Thats quite a few solar panels. How many batteries?
I'm charging my winch battery with one panel - like 8 by 8 inches. Works great. |
What's the Amp Hour draw of the fridge? My RV has a residential fridge and it KILLS the batteries. I've resorted to freezing milk jugs of water and using the fridge as a big cooler overnight instead of trying to keep it running off the batteries.
Originally Posted by 177mph
(Post 15835830)
Originally Posted by DTMiller
(Post 15835879)
I have just a few days to get trailer ready for the season so more pics over the next few days. New rubber all around too. Todays progress. Goose neck trailers have an attic and it is called a storage attic for a reason. Stuff goes up there and if out of reach it stays there. Collection of useless crap. Pic of wire penetrations from the roof. https://cimg9.ibsrv.net/gimg/rennlis...8d9f17b3a7.jpg Attic appears to be empty. Why? Pic below. https://cimg8.ibsrv.net/gimg/rennlis...5255b964cc.jpg And that is not all of it. Today was rain and overcast and I measures 40+ volts on one of the panels, open circuit. Yard area will have partial shade at all times and these cells should keep batteries topped off. Battery pit below. Optima on left is toast. It was charged by the truck and powered only landing gear and winch. Trailer circuits drained it to total flay over the winter, second time for that. Toast. Have a replacement. This battery pit gets re worked and a third Optima added. They will all be charged by solar and truck will only charge the brake battery of the trailer. I hope these cells can generate even enough juice to keep the batteries full with snow covering the roof. We will see next winter. https://cimg9.ibsrv.net/gimg/rennlis...0e9183d473.jpg |
Instead of 3x batteries check out commercial 4D or 8D sized batteries. They're usually used in diesel heavy equipment. It would simplify wiring if nothing else.
What kind of charge controller and inverter are you using? |
I have a renology 100W system, I upgraded to 400W, using two marine batteries and a 2KW inverter for my trailer. Love it. Mainly use it for charging things, (phone, batteries, scooter, car), lights, and the a fan when needed. I haven't added a fridge or anything like that -- but might.
Is there a portable ice chest/fridge freezer setup out there? Not having to buy ice and re-freezing my cool suit bottles would be awesome. Mike |
Originally Posted by BillNye
(Post 15837165)
Originally Posted by txhokie4life
(Post 15837473)
Is there a portable ice chest/fridge freezer setup out there? Not having to buy ice and re-freezing my cool suit bottles would be awesome. Mike Today all I got done was the MP4 connectors crimped to the panel leads, and location chosen for the charge controller. Installation may go live tomorrow, but may not be tidy just yet. Since I have 4 panels I am going with series parallel with the panels. 2 panels in series connected to 2 other series panels connected in parallel. Higher voltage supplied to controller with smaller wire. The TS-60 can handle 125 volts open circuit so the 80+- from series parallel will be fine. Battery pit is also part of this project. Must get done too before heading out Friday. |
Originally Posted by Mussl Kar
(Post 15838677)
I forget the inverter brand. Maybe pics of it tomorrow. Charge controller in a Morningstar Tristar TS-60, PWM type. Bought because original plan was 800 watts of solar panel.
Amazon is your friend here. Almost all 12 volt units can be freezers. Just skip the solid state units. I set the temp to be fridge, not freeze. There are a few units with dual temp zone$. Today all I got done was the MP4 connectors crimped to the panel leads, and location chosen for the charge controller. Installation may go live tomorrow, but may not be tidy just yet. Since I have 4 panels I am going with series parallel with the panels. 2 panels in series connected to 2 other series panels connected in parallel. Higher voltage supplied to controller with smaller wire. The TS-60 can handle 125 volts open circuit so the 80+- from series parallel will be fine. Battery pit is also part of this project. Must get done too before heading out Friday. Good luck with the project. |
We've found in the transporter that if we fill fridge crisper trays with ice and don't load the fridge with not cold drinks at the end of the day, it will stay cold overnight not running. It ends up with enough mass to keep cool.
You guys are pretty amazing. I replaced the battery that powers my winch and lights and I thought was superman afterwards.
No pics of tonight but got all MP4 connections done in the "attic" and brought to the charge controller. #10 wire from each series pair. Neg from solar connected to controller and time for dinner. Positive from solar needs to have a switch disconnect and that may happen tomorrow evening. Now 80+ open circuit volts so prob wear gloves for final connections. Not touching my tongue to the wires.
(Post 15841126)
Can the panel handle that? |
Originally Posted by LuigiVampa
(Post 15841978)
You're in Mass so you get snow like me here in CT. I have noticed a ton of weight on my trailer over the course of the winter.
Progress report. Panels are now wired to controller and disconnect switch is in that circuit. Taking part of tomorrow off to finish the battery pit and other stuff. Roll to first DE around 1 PM Friday.
