Post a picture if your truck + trailer combo!
Old 02-12-2019, 10:12 PM
  #31
GoatFarmer
GoatFarmer's Avatar
I need to up my game; especially when I buy a cup car. Imagine me pulling up in this heap with a cup car on it?
Old 02-13-2019, 09:52 PM
  #32
ShakeNBake
ShakeNBake's Avatar
Old 02-18-2019, 12:21 PM
  #33
Kein_Ersatz
Kein_Ersatz's Avatar
Run what you brung...
Towing over the years...
Old 02-18-2019, 01:29 PM
  #34
tgsmith4845
tgsmith4845's Avatar
Thor ACE 30.4 RV, Triton 6.8l V10 gas, 460 lb-ft torque, 8000# tow capacity. Fully loaded (SPB, tires, tools, awning) 22’ ATC Quest all aluminum trailer weighs 6000#.
Old 02-20-2019, 11:38 AM
  #35
Steve113
Steve113's Avatar
No trailer to worry about
Old 02-20-2019, 09:19 PM
  #36
awrryan
awrryan's Avatar
2012 Range Rover Sport. Trailex 7541.
Old 02-21-2019, 12:47 PM
  #37
JRMaroon
JRMaroon's Avatar
Here is the towing setup I ran for the last two years. This rig has been replaced by a 2009 Chevrolet Kodiak Ambulance which will make it's maiden voyage in April.
Old 02-24-2019, 10:59 AM
  #38
DTMiller
DTMiller's Avatar
The tow rig has juuuuust enough powah.
Old 02-28-2019, 12:32 PM
  #39
rnh204
rnh204's Avatar
Tow with a 2014 QX80. Enclosed trailex. Used to have the gt3rs that I have since sold. Will be driving a fully prepped e46 m3 this season.
Old 02-28-2019, 03:01 PM
  #40
ShakeNBake
ShakeNBake's Avatar
I miss my .2RS
Old 03-01-2019, 03:14 PM
  #41
russell263
russell263's Avatar
Originally Posted by wake74
Mine doesn't begin to compare to some of the trailers that regularly appear in this forum, but it fits with the track rat (high smiles per dollar) nature of my E36. It's a basic 20 foot enclosed V-nose, purchased before the holidays. Like the track rat, it was purchased cheap, and then upgraded. To-date I've stripped the walls, insulated walls and ceiling, installed luan on the ceiling, painted, wired in 30 Amp Electrical, LED lights, epoxy flooring, etc. I'm into it for about $4,500, so can't really complain. Tow pig is an '07 Tundra.
How is the epoxy floor holding up? I have heard it is prone to cracking since the wood floor flex. Also, anymore photos of your V nose work bench, how is it attached? Is it custom?
Old 03-01-2019, 07:41 PM
  #42
wake74
wake74's Avatar
Too early on the floor. I've only used it for part of one weekend. The first THSCC HPDE weekend at VIR was called after just a couple of sessions on Saturday morning due to severe rain, and flooding in the run-of areas. I suspect I will get a bit of cracking over time, but it's much nicer than the dirty bare wood floor that was in there. It was also cheap, just the basic Rustoleum Garage floor, and matching clear coat you get at the big box stores. I did add an 8'x12' section of "quality" $0.40 / SF carpet from HD to roll-over the floor when in sleep mode. A little nicer on the feet than the bare floor. I was pleasantly surprised that the trailer stayed comfortable (75 degF) with a outside temp nearing 40 using just a small space heater. The insulation seems to have worked out well. The trailer came with one of those portable ac units, but I'm not sure that will be enough come this summer, despite the insulation. I'll add a proper RV roof unit if need be after I test out the portable unit.
The workbench is just half sheet of 3/4" plywood, with 2 ea. 1"x4"x8' boards. One board across the front, one cut into pieces and screwed to the front wood. I wouldn't want to rebuild a tranny on it, but it works well for a countertop and was cheap. More countertop than custom workbench :-)
NYoutftr (11-14-2020)
Old 03-01-2019, 10:38 PM
  #43
awrryan
awrryan's Avatar
If you pulled up with a cup car towed by that “heap,” I’d say that you’re a smart man and know where to put your money! And I’d be insanely jealous!
Old 03-07-2019, 09:59 AM
  #44
dgmark
dgmark's Avatar
Default New ride for 19
32' Gooseneck AC Generator Ect, What will be sweet is that I am having made a 80 Gallon fuel tank to fit under the floor, no more schlepping 5 gallon cans to the station.
Old 03-07-2019, 10:20 AM
  #45
fnel1771
fnel1771's Avatar
Graduated from an Acura MDX to the MB Bluetec. Twice as fuel efficient and can tow at 70mph under all conditions and does not even change gears!
Quick Reply: Post a picture if your truck + trailer combo!
