ATC Quest 22' Order
#61
Think it's called a beavertail. I also bought 4" Race Ramps that are about 46" in length to help load the GT3.
#62
Also I had 46” race ramps and they were too steep for my GT4 (no axle lift option)
#63
For comparison, here is an identical Featherlite trailer (although 24') that does NOT have the raised 6" deck.
Crazy how high the escape door is on those. When I searched inventory nation wide, most were like this.
Even with the raised 6" deck on mine, I am still going to need 2" Race Ramp Trailer mates for the front tires.
I'm hoping that with my FAL, my 4" Race ramps will work to get the car in safely.
Thx again.
Thx again.
#65
Wow that is pretty high - why did you do that? do you have a steep driveway or something?
Let us know how it goes - the axle lift will help you but I think you're going to need some pretty long ramps. Also do those fenders pop out? not seeing how it will work with escape hatch.
@BlazinPond
@BlazinPond
#66
By driving the front wheels up on the 2" Race Ramp Trailer mates inside the trailer, I will have a 1-2" of door clearance.
As far as driving up the ramps/door, the 6" raised deck is gradual once inside the trailer.
Therefore, it shouldn't be any different entering the trailer (raised deck or not).
Hopefully I don't have this all messed up....
Worst case, I will need to order the 5" or 7" extended Race Ramps that have a 67" or 74" length.
No, the fenders do not pop out. That would have made things a lot easier if they did....lol.
#67
It makes sense now - why you raised the deck, though I am not sure why Featherlight would not offer a configuration similar to ATC so you wouldn't have to have it so high.
Anyway, hope it all works out well for you!
#68
Now I'm all nervous that this trailer sits up too high.....so I backed out since dealer has many other similar trailers.
I will start a new thread asking for feedback this time!
Thx again.
#69
Some funny bits about our wives there:
- The enclosed trailer was my wife's idea, however the one she spec'd was the $12k steel and wood variety - I told her to step aside and let me spec it haha
- Now that the trailer is done she agrees it was worth it - though she still had a bit of sticker shock when I told her how much
- I notice a blue M2 in your avatar, my wife drives one has her track car but just had it wrapped purple!
I noticed you have added a proper race seat and harness in the M2, would it be ok if I PM you for some information on that mod? I really need to do the same to gain safety and some head room.
Tom
#71
I had a similar predicament,could not open the door due to the trailer wheel well. Took the advice od others and installed a winch and do not use the side door. One of the best things I did
#72
#73
I put this in another thread, but might as well re-post here. My new favorite trailer accessory, battery powered compressor with 2.5 gallon tank:
Way faster than 12v compressor, and super portable. Pickup and one handed and walk around car, easy. Here's inflating from 22-36 PSI:
Packs away easy.
Packs away easy.
#74
Do you have any pictures of your solar wires going through the roof and cabinets? I ended up getting that black 305 at 99W as a surprise present and doing the solar myself since they're so far away from me.
#75
Also the solar panel is one of the flexible stick on varieties.
