Minimalist trailer set-up
Have not had a chance to take/post a picture of the set-up yet, so here it is on the way to VIR. Using the t-hook holes in the bottom of the car in an X pattern front and rear, an oh-$h1t safety strap through the rear wheels, and chocks. For the extra strap, mounted ratchets on square aluminum tubing bolted to the side of the trailer (Featherlite 3110, 1100 lb) with SS hardware. Backed it on to get the tongue weight right, and it makes getting to the straps on the front of the car (back of trailer) easier. This trailer (with car) fits in the 2-car garage that came with the house. The garage has a bit of extra depth, but not a huge amount. Pulling it with a Buick Enclave (V6 FWD). It's not great (struggles up hills some), but gets by. I'm within the pulling weight limit by a decent margin, but just about on the rear axle limit. Still considering a stronger tow vehicle...
A bit of a funny story...packing up to return to the house, I could not find the T-hooks. Spent forever looking for them. Turns out the hooks built into the straps fit right into the holes and you do not need the T-hooks! After driving for about 10 minutes, I remembered I stored the T-hooks in the built-in bin in the back of the Buick - duh!
I would be seriously considering a different tow vehicle, mostly becuase I couldnt stand to drive an Enclave, towing or otherwise.
Nice setup though. I'm glad to see more people using T-hooks.
WRONGLY ACCUSED!
Received 3,286 Likes
Can you put a weight distribution hitch on that trailer? Most people don't realize that when they look at their vehicles maximum towing weight it is with a weight distribution hitch.
You already know this but yeah I would definitely look at upgrading the tow vehicle. We have a GMC Acadia Denali (same basic platform) and a Nissan Armada and it is night and day difference towing. The Acadia can do it if necessary but the Armada can do it without really noticing .
Nice setup! I’m looking at doing something similar with my GT4.
When you say t hook holes do you mean the holes in the jacking location?
Also, are you using additional ramps to get on/off the trailer and if so where do you store them?
Really like how you put the DE numbers on the car, suits the car well.
Did you actually measure your tongue weight loading the car this way? Sorry but it just doesn't look right.
+1 That does not look right.
I wouldn’t be surprised if you had about 1000 lbs of tongue weight with this set up. Have a look here:
https://sherline.com/Wordpress/wp-co..._booklet_2.pdf
As long as you actually measured it. The optics are definitely deceiving.
Interesting point about the effect of tilt (50 lb of weight for each inch raised). I've never considered that before but it makes total sense.
