Trailer TPMS - what are you running?
Old 03-13-2018, 09:27 PM
badabing
badabing's Avatar
Default Trailer TPMS - what are you running?
Working on getting my new to me Trailex open trailer set up. I definitely want tire pressure monitoring and was wondering what folks have been using...
Old 03-13-2018, 10:15 PM
jwasilko
jwasilko's Avatar
I have a TST 507 on our truck and trailer. It's been great.
https://tsttruck.com/
Old 03-13-2018, 10:25 PM
stujelly
stujelly's Avatar
there are some kits that let you use your cell phone as the screen and monitor, saves having another device on your dash.
With apple car play I would think you could get it to show up on the dash of your truck
Old 03-14-2018, 12:08 AM
MSWNCity
MSWNCity's Avatar
I have been using this EEZTire system for a few years. It has saved me several times. I wouldn't tow without a TPMS monitor system.
Amazon Amazon
Old 03-14-2018, 11:28 PM
Kein_Ersatz
Kein_Ersatz's Avatar
Amazon CACAGOO $75.99 4 internal sensors and display
Old 03-15-2018, 07:12 AM
badabing
badabing's Avatar
Kevin,
Are you actually using this product?
I was looking for internal sensors and you can't beat the price.
Just want to make sure this actually works and that the range is sufficient for the trailer tires?
Old 03-17-2018, 10:27 PM
Kein_Ersatz
Originally Posted by badabing
Kevin,
I am using valve cover caps currently on Trailex and an SUV with reader plugged into dash, range works. I am swapping out Trailer tires in a month (Goodyear) or so and will switch to in valve units. Will report back, but the caps worked fine. Battery life is an open question, had to replace cap batteries in year 2. So if that is the life span for the valve stems, that could be a pain.
Issue with caps is setting air pressure, then screwing on caps loses some air.
Old 03-17-2018, 11:03 PM
ShakeNBake
ShakeNBake's Avatar
https://www.amazon.com/EEZTire-Tire-Pressure-Monitoring-System/dp/B009BFMUHQ/ref=sr_1_1_sspa?s=automotive&ie=UTF8&qid=1520996749&sr=1-1-spons&keywords=eeztire+tpms&psc=1
Same here, good luck with it for about a year. transmitters/sensors eats batteries though - buy spares.
Old 03-18-2018, 11:37 PM
MSWNCity
MSWNCity's Avatar
My EEZTire monitor plugs into my 12v outlet.
Old 03-19-2018, 05:11 PM
ohenryinatlanta
ohenryinatlanta's Avatar
which is a good "cap" system ?
thx
Old 03-20-2018, 04:57 PM
Viperbob1
Viperbob1's Avatar
EEZTire system
Old 03-29-2018, 10:34 AM
KOAN
KOAN's Avatar
I've been using tire minder. Looks like it might be more expensive than some of these options, but it has been reliable for 3 years and tells pressure and temps, with alarms when something goes wrong.
Old 03-29-2018, 11:44 PM
mbean
mbean's Avatar
The eeze link says not to use on towed vehicles or trailers. Can they be used on trailers?
Old 03-29-2018, 11:53 PM
ExMB
ExMB's Avatar
Received 1,310 Likes on 796 Posts
Originally Posted by mbean
The eeze link says not to use on rubber valve stems or towed vehicles or trailers. Can they be used on trailers?
FIFY
Old 03-31-2018, 06:28 PM
MSWNCity
MSWNCity's Avatar
They absolutely can be used with towed trailers. If fact the set up guide shows how to configure your display so it rotates through the different sensors, including a trailer if attached, showing pressure, temperature and warning if any of the sensors falls outside of your programed limits.
Quick Reply: Trailer TPMS - what are you running?
