X5 35d - should I spec w/ self-leveling?
I am going to trade in my F15 X5 35i for a new F15 35d and I am trying to decide whether to spec it with self-leveling air rear suspension, which also comes with dynamic damper control. The alternative is the standard coil spring suspension with struts that are not electronically controlled. I'm weighing potential reliability issues related to self-leveling vs. performance advantages the system may offer in terms of towing. I will be towing a Trailex open trailer with a GT4 on it. My 35i did not have the self-leveling option, and it did get the job done, but the rear end did sag moderately when the loaded trailer was attached. Obviously, self-leveling would prevent sagging and perhaps avoid any associated handling issues, but it is also more complicated and prone to failure than a standard coil spring strut. Anyone have any thoughts that my help me decide?
I had air suspension on my Cayenne and my Q7 and it is an absolute must for me if you are able to spec a tow vehicle from scratch. It also helps when you have to load a low clearance car on your trailer as you can raise the rear of the tow vehicle and reduce the ramp angle on the trailer. I have no idea whether those systems a failure prone on BMWs.
Also: Get a tongue weight scale and check your tongue weight for correct car positioning.
Yes, absolutely get the self leveling rear suspension. Especially since it's going to be a brand new tow vehicle and have a warranty, what's to worry about if something does fail for the first several years? Regardless, even outside of warranty (see my 102k mile Cayenne Turbo for example) I would rather pay the repair costs of the air suspension than tow without it. Having towed thousands of miles with at the very least rear air/self leveling in a Denali, Yukon XL, RAM 2500 and even a RAM 3500, it's a 100% must have if at all possible on a tow rig. The benefits, both towing and unladen, far out weigh the potential "what if's" your brain is conjuring.
When in doubt, ask your salesman to let you take a test drive in an X5 with the rear air suspension and your trailer, you'll notice the improvements immediately (though this could be complicated if the X5 doesn't have a built in brake controller- which I presume it doesn't. Prodigy RF to the rescue!).
First and foremost, ride quality. Both with and without the trailer, is significantly improved, with the air suspension. Even rear seat passengers (I believe the 3rd row option is not available with the air suspension though?) will appreciate the improvement in ride quality. As for why it becomes a no brainer to me if you're towing with the vehicle, even semi-regularly, is the stability it offers over the standard suspension. Even with a light open trailer, it's still critical that your tongue weight, and therefore your car placement on the trailer, is correct. Assuming a 3200lb GT4, a 1500lb trailer, and lets say 200lbs of fuel, spare tires/wheels, jack, what have you, you're at just shy of 5000lbs. At that point, your minimum tongue weight should be 500lbs and upwards of 750lbs if you go to the high side of the 10-15% rule of thumb. That's a solid amount of weight to expect a mid size SUV rear suspension to haul well behind the rear axle. Almost any factory steel coil spring suspension is going to experience significant squat at those weights, which is where a weight distribution hitch comes into play. However, there's only so much a WD hitch can do (I used one in conjunction with the air/self leveling on my Denali) to get the whole setup happy and level again. The major negatives of too much squat are light steering feel, reduced braking capability, and everyone's favorite- headlights pointed at the sky. When you take into consideration a lot of aluminum trailers can't be used with a WD hitch (without additional reinforcement plates), along with the added cost/setup/etc of a WD system, the self leveling rear becomes the much more elegant solution.
With all of that said though- I'd double check on the weight ratings of the hitch setup of the X5 as it (presumably) will be a Class IV setup which means it will have two different tongue/GTW ratings. One will be weight carrying- which is the amount possible with just a standard tow bar/ball combo. The other will be weight distributing- which will require the use of a weight distribution hitch in order to use those higher amounts. More than likely you'll be fine with just the weight carrying capacities which means the self leveling is a must in my book- otherwise you'll be squatting with no easy solution. If your weight exceeds those limits, and you have to go with a WD setup, then you will need to confirm a WD hitch can be used with the self leveling suspension (for example- Porsche does not allow it- but that's because it's a full 4 corner system. The Denali was only rear leveling and DID allow WD hitches) and then decide if the benefits of the self leveling still make sense. To me, they absolutely do, but it's a lot harder to justify if you don't have the ability to test the system towing ahead of time.
Third Row option automatically comes with the self leveling option. I'm on my second X5d with third row. Tows an open trailer very well. No rearend sag and you hardly know the trailer is there.
DO NOT use a weight distribution hitch on an X5. The hitch is mounted to 4 bolts on the unibody. The torque from the WD setup can literally twist the chassis. BMW and Execuhitch both specifically warn against using a WD hitch on the X5. Keep tongue weight below 600 lbs and you'll be fine with the self leveling suspension.
I have the self leveling suspension that comes with the third row seat. I don't know for sure
if it includes the DDC option.
Definitely install the factory tow wiring harness. This will interface with your suspension and adjust appropriately when towing.
I've now done the hitch install on 3 X5's. Very easy including the wiring. The invisihitch is a better option than BMW factory (IMHO).
Thanks. I have the BMW factory wiring harness and lighting control modul and an Invisihitch on my X5 35i now and it has worked out great. I was already planning to have the dealer just transfer all of that equipment to the 35d when it arrives. Hopefully they will be able to do that without any issues. My 35i is a 2017 and the 35d is a 2018, but I believe everything should still fit the same on both trucks and hopefully the technician will be competent.
Btw, do you have the Dynamic Handling Package on your 35d? I am seriously considering adding that having read so many positive reviews of it, but I am concerned about how reliable the components are. I understand that it uses a special differential, and I don’t know if it is as robust as the standard diff. BMW’s website doesn’t even discribe the components, and instead just says the package improves handling, so I am really working with imperfect information.
Edit: I just realized you already answered the question whether you have DHP. I read your post in my email and did not see your respnse to the question. Let me ask a related question though: how do you like the suspension on your X5 both for towing and for everyday driving. My X5 will be my daily driver as well as my tow vehicle and I want to avoid suspension that is too soft. I have read a lot of complaints regarding the standard coil spring suspension but I have that setup on my 35i and it seems fine. I definitely want to get self-leveling/air this time, but DHP includes those features too.
I beat on my F85 X5 on the track (has dynamic dampers and rear air suspension), and tow an enclosed trailex 4K+ miles and it's been pretty solid. I can't imaging you'd ever put that much load on it occasionally towing an open trailer and as a daily driver. Also never had any trouble with my 2013 E70M.
