Enclosed trailer, loaded interior pictures
#31
My guess here is that you don't have a side exit door and are winching it. Therefore you statement needs to be modified and not presume an assumption (based on your personal experience with selected your box) being applicable to everybody out there.
My car balances just fine in my 24' and its loaded nose first and NOT a$$ first.
#32
Finally got around to getting some pics of my 24' ATC trailer. Thanks to all for your input above.
It's a 24 ft ATC Quest custom Spec with large escape door, upper front cabinets, aluminum ceiling, plywood walls, Polylaminate flooring, Custom Built Front shelves/ Tool cart, 5200 Lb Torsion Axles, LED lighting, 30 Amp Electrical panel, Extended tongue, Aluminum wheels, 2 spares mounted on walls, Shoring Beam Tire rack mounted high enough to drive under, rear facing loading lights and wireless backup camera, slideout step for entry door. AC/Heater and generator box on the tongue will be next.
Tongue weight with Boxster positioned as seen in pics is right around 700 lbs. Total loaded weight is around 7000 lbs. Once the generator is mounted, I will pull the car back a bit to keep tongue weight at about 700 lbs.
#33
I bought my trailer used, but if I was going to build one from scratch, the escape door and AC prewired and framed would be on the top of the list. So much easier to get out of the car, and putting in an aftermarket AC is easy and much less expensive. Inground winch might be nice depending on what else you're storing up front, but inground spare doesn't make sense to me. Can't get to it when you really need it. A friend did the gas tank and pump, and never uses it. cabinets and generator compartment and you're good to go. All the other stuff you can add as you go. And yes, the 24 is worth it, because you always end up needing more room than you thought you would. Even an extra foot makes it a lot easier to get down and tie the car down, etc.
I ended up making a billet aluminum bar through bolted to the front frame and the winch mount can slide left to right depending on tow eye location. Cable now winds properly.
