Trailer insulation
Trailer insulation
New trailer has no ceiling insulation. It is a seamless ceiling braces 24in on center. Any ideas on how to insulate it will be much appreciated.
Here are a couple of suggestions.
A simple peel and stick insulation is Dynaliner by Dynamat http://www.dynamat.com/
Comes in different sizes and in bulk rolls. Does a good job of reducing heat and noice.
If you feel more adventerous, you can opt for Lizard Skin http://www.lizardskin.com/car-ceramic-insulation.html
This one is a spray on so you will need some specialized equipment including a compressor. Also does a good job on heat and noise.
I've used both on past trailers and both are good for a significant drop in radiant heat so your A/C doesn't have to work as hard.
