20" BBS CH-R and H&R Springs for 991 C2S
Up for sale is the exact setup in the pictures - I only had this setup since late June till now. The wheels are in perfect shape, no rash, knicks or anything and have been meticulously washed and cared for weekly using the Obsessed Garage methods.
Wheels are currently located at Supreme Power in Fullerton, CA. ooBBS CH-R with Michelin P4S - $3500 picked up, buyer responsible for shipping (although I prefer not to ship) Front: 20x9.5 ET49 - 245/35/30 Rear: 20x11.5 ET65 - 305/30/20 Tires have approx 3000 miles on them and were installed and alignment done since day 1, tread wear should be very even. I ran a 7mm spacer up front and 14mm spacer in the rear, I'll have to check if I still have them or if I'm using them on my e88's - but can negotiate those too. oo H&R Springs for 991.1 C2S - I think compatible with other models as well. - $350 shipped |
Do you have weights for the rims?
Originally Posted by titleistaddict87
(Post 15403698)
BUMP
How much did it lower the car from original setup? tire life? how old are the springs? i know you mentioned since June, is it everything? |
Originally Posted by Marco Moran
(Post 15411625)
How much did it lower the car from original setup? tire life? how old are the springs? i know you mentioned since June, is it everything? Everything was installed new in June and aligned. Wheels are basically new - maybe 3000 miles on everything. Ended up getting different wheels and coil overs, only reason I'm selling. |
