1985 Porsche 928S
Mechanically sound 1985 Porsche 928 automatic for sale: Mileage in specifics is out of date, actual today is 91,883 (sorry, cannot seem to edit).
The Good: Timing belt and water pump replaced in 2018 (based on 10 year, not mileage - removed parts in good condition) Crankshaft end play checked (very good) and flex plate clamp reset, installed secondary clamp. Engine oil and filter changed regularly, less than 1,000 miles per oil change Engine compartment fuel, coolant, and vacuum lines all replaced Intake and accessory brackets powder coated Brake calipers rebuilt with rotors and pads replaced Rear axle shaft CV joints greased, and boots replaced New front spoiler and protection plates installed Steering rack replaced Power steering pump rebuilt, reservoir and hoses replaced Hard spare tire cover installed Full set of factory service manuals included Stored in heated garage, not driven in winter The Bad: Driver's seat outside bolster worn badly Windshield cracked (not in driver line of sight, not progressing) AC doesn't work (never evaluated) Small power steering fluid leak at rack connection One speaker in each door work (complete set of speakers included but not installed) Coolant warning light always on (level sensor okay), reset warning after starting Taillight warning when lights are on, all lights functional Radio antenna replaced with strip type in right A-pillar trim Reason for selling: Only drive a few hundred miles a year, about one tank of fuel |
Decided to pull the car from sale at this time. May repost at a later date.
Thank you to all that viewed the listing. Roger aka WICruiser |
