Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   The Rennlist Marketplace (https://rennlist.com/forums/the-rennlist-marketplace-251/)
-   -   1988 Porsche 928 S4 - 5 Speed (https://rennlist.com/forums/the-rennlist-marketplace/1143544-1988-porsche-928-s4-5-speed.html)
Rob Roy 05-17-2019 07:12 PM
$17,500 OBO
Runs and drives very well.
Located in Trinity, TX
Details
1988 Porsche 928 S4
Guards red with black/tan interior
(From VIN Decoder)
1988 928
C03: California
Motor: M28.41
Transmission: G28.13
Options:
I158 - Radio Blaupunkt Reno (no longer with car)
I302 - Type designated on rear end
M474 - Sport shock absorbers - Bilstein
M481 - Five Speed Manual Transmission
M494 - Additional Amplifier
M570 - Rear A/C
M650 - Sunroof
Showing 143,700 miles - odometer gear broken - estimated 5,000 - 6,000 additional miles
A/C not working - I am planning on getting it fixed by early next week
There is a small transaxle oil leak - I believe it is a seal and will replace early next week
Modifications
Genuine Porsche "Turbo Twist" 18" wheels with 225/40 tires on front and 295/30 tires on rear
X-Pipe with no cats
RMB
Short-throw shifter
Air pump delete
Momo steering wheel (original steering wheel included)
PorKen Fuel & Ignition Chips
High low injectors
Recent Work
New clutch assembly and rebuilt clutch slave cylinder within last 5k miles
New timing belt, waterpump, and PKT-S Porken tensioner within last 500 miles
Exterior Condition
Single stage paint is getting thin in places
A few minor nicks and scratches
Some paint cracking on front bumper
Front spoiler cracked and removed, but comes with car for possible repair
Some slight hazing/cracking of the rear taillights
Headlights will sometimes exhibit moisture inside
Small chip/hole in DS driving light
Thin crack running down windshield
DS door lock not working - PS works fine and locks both doors
Some deformation of exterior floor pan rails due to improper jacking by PO (unfortunately as is common in these cars)
Interior
Tear in DS seat bolster
DS floor mat worn
Dash and pod are cracked - comes with 928Motorsports ABS dash and pod covers (not installed)
IIRC the toolkit is complete (I'll check this weekend)
Air compressor
Spare Tire
What it Needs
1. Top end refresh
2. Motor mounts - new motor mounts included
3. Oil pan gasket - new gasket and studs included
4. Rear CV joint rebuild (slight rumbling and torn boot - PS rear) - CV rebuild kit included
5. Odometer gear - new odometer gear included
Other Items Included in Sale
PorKen Lift Bars
Complete set of Workshop Manuals (Gray Folders - these have been sitting in the garage and have been well used, so expect some wear and tear)
Kempf Timing belt tension tool
Flywheel lock
Center console
Gas tank (from another 88 -excellent condition)
