Stomski Racing GT3 Cam timing apparatus
For SaleMiscellaneous
I have a barely use Stomski racing GT3 Cam timing Apparatus model SR090V2.
Web page is here: https://www.stomskiracing.com/produc...iant=959932507
"Whether you want to advance or retard cam timing, upgrade cams, or just be able to set with ABSOLUTE precision the cam timing on any of the GT3/GT2 engines, this is the most accurate tool to accomplish those tasks. No need to settle for the "close enough" or in the "ball park" settings accomplished by using the factory tools. STOMSKI RACING's GT3 Cam Timing Apparatus provides for absolute accuracy, infinite adjustability, and superb flexibility for all cams and setups. Includes complete fixture with ASME/ANSI certified dial indicators and one (either 12mm or 14mm) TDC Indicator with Travel Gauge (SR092 or SR093). Storage case included."
If you have ever used Steve's tools, then you know that his stuff is as good or better that the Factory stuff!
This is very lightly used, and I really don't plan on building many more GT3 motors, and if I do...
This is the latest version of the tool...
