Complete 957 Turbo S Big Red Brake Setup - 32k miles - Calipers, Rotors, lines, pads,
Brakes
  • Brakes - Complete 957 Turbo S Big Red Brake Setup - 32k miles - Calipers, Rotors, lines, pads, - Used - 2005 to 2010 Porsche Cayenne - Seneca, SC 29672, United States
Petza914 is offline
    $3,500
  • Location Seneca, SC, 29672, USA
Porsche Cayenne 2005 - 2010
I did a PCCB upgrade on my widebody 2009 Cayenne over the Holidays and now have the complete Big Red Turbo S brake setup that was on the car available for sale. Could be used by 957 Turbo owners to upgrade to the larger 380mm x 38mm Turbo S brakes or by a Turbo S owner who need rotors and pads, and will also give them spare calipers or calipers in better shape. May also be retrofittable to the 955 series Cayennes (measurements provided so you can verify wheel carrier bolt spacing).
Upon removal, I sealed the caliper brake line holes with Teflon taped screw in plugs and then cleaned everything in my heated, ultrasonic parts washer with aluminum safe degreasing agent. Calipers look like brand new with a few little bumps and bruises from 32,000 miles of use.
Included are:
  • Loaded Left Front Caliper & Rotor (includes pads, pad wear sensor, retaining clips, etc). Front left rotor thickness is
  • Loaded Right Front Caliper & Rotor (includes pads, pad wear sensor, retaining clips, etc)
  • Loaded Left Rear Caliper & Rotor (includes pads, retaining clips, etc, but No pad wear sensor)
  • Loaded Right Rear Caliper & Rotor (includes pads, retaining clips, etc, but No pad wear sensor)
  • Both Front Rubber flex brake lines that go from the hard line connection at the top of the wheelwell to the hard line connection midway down the front wheel carrier (Does not include the front hard line from the flex line to the caliper)
  • Both Rear Rubber flex brake lines and hard brake lines that go from the hard line connection at the top of the wheelwell to the caliper itself (Does not include the black clip that holds the caliper line joint and pad wear sensor plug)
One front Rotor has a thickness of 36.54mm and the other 36.47mm so good life left in these. Front pad thickness is 9.15mm.
Both rear Rotors have a thickness of 26,87mm. Rear pad thickness is 9.09mm. I renewed the rear pads at 30,000 miles, so less than 2,000 miles ago.
For a price reference on what this setup would cost new, here's the link to Suncoast's page - https://www.suncoastparts.com/catego...TTSBRAKES.html
  • Front Rotor Set - $1,475.50
  • Front Pad Set - $239.23
  • Front Pad Wear Sensor Set - $52
  • Rear Rotor Set - $295
  • Rear Pad Set - $168.23
  • Wear parts SubTotal - $2,230
Plus,
  • Front Left & Right Calipers, which run about $1,000 each new or $500 each used (regular Turbo, not the S)
  • Rear Left & Right Calipers, which run about $400 per pair used with pads
  • Also included are the rubber flex lines for the Front & Rear brakes and the metal hard lines for the rear brakes.
New, you'd be looking at about $6,000 for this setup. Get this low-mileage one for more than 40% off.
Front caliper as removed - yuck. Moved pads inward to be able to clean between the pad carrier plate and caliper wall.
Threaded plug sealing caliper so no cleaning solution could enter the caliper. Note calipers placed on rubber pads to not mar the finish from the ultrasonic action
Ultrasonic waves removing caliper dust, grime, etc. You can see it floating off the calipers
More dirt floating off
All Cleaned up - Logo Sides. Front Pad wear sensor wires were bagged to prevent ingress of the cleaning solution to the electrical connectors.
All Cleaned up - insides
All Cleaned up - outsides
Rotors Cleaned up too - outsides
Rotors cleaned up too - insides
Front Rotors - outsides
Front Rotors - insides
Rear Rotors - outsides
Rear Caliper Hard Lines (did not go into the parts washer)
Front & Rear Rubber Flex Lines (Did not go into the parts washer)
Front Rotor 1 thickness
Front Rotor 2 Thickness
Rear Rotors Thickness (both the same)
Front Pad Thickness
Rear Pad Thickness
If you need to verify whether these will bolt up to your Cayenne, here are photos of the Front and Rear Caliper to Wheel Carrier mounting bolt spacing.
Front Caliper to Wheel Carrier Mounting Hole Spacing
Rear Caliper to Wheel Carrier Mounting Hole Spacing
Thanks for taking a look and let me know if you have any questions. I have more take-off parts here from my 2009 Turbo S in a prior Marketplace thread prior to the format changeover - https://rennlist.com/forums/parts-ma...l#post15316491
Old 04-22-2019, 12:32 PM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
Old 09-28-2019, 07:53 PM
Kyle Spurgeon
Kyle Spurgeon's Avatar
I assume these won't fit a 958.2 Base?
Old 09-28-2019, 08:05 PM
Petza914
Petza914's Avatar
I don't know. If the base 958 calipers mount through the top of the caliper then probably not. If they mount through the side into the wheel carrier then check the spacing of the mounting bolts from the photos in the ad I posted.
Another option might be to source 957 wheel carriers that these would bolt up to if those will also fit a 958.
I also have a pair of rear PCCB 958 calipers available. Those would likely bolt up and you could source appropriate rotors and pads to utilize them.
They're in this ad
https://rennlist.com/forums/market/1124983
Old 11-03-2019, 01:42 AM
Petza914
Petza914's Avatar
Complete Turbo S Brake Kit is now SOLD !
