Strokher Racing |
01-06-2019 07:54 PM |
Fully built G50/52
I have a very unique, and rare transmission I no longer need. This tranny was built for a big HP turbo car, but I ended up abandoning the project. I returned the car back to close to stock so a stock 50/52 went back in it. The tranny was initially built by Chris Cerevelli. I wanted to make some changes so I had Cory Jump rebuild the tranny. It has a modified gear set with the following.
1st gear is a stock turbo 3.154
2nd gear is a non turbo 2.059
3rd gear is a non turbo 1.407
4th gear is a turbo .967
5th gear is a Guard custom .679
The tranny has a REM finished turbo ring and pinion it. Has all steel synchros in it. CMS billet shift fork. CMS Billet side plate. It has a GT3 cup differential in it. It has a SPEC stage 3F clutch and pressure plate on it. That was used for 40 street miles before the tranny was torn down. I am including a Turbo Kraft semi solid mount and transmission crossmember as well. Everything is fresh, and ready to go. This thing is built with no expenses spared! You WILL NOT FIND ONE LIKE THIS! A stock 50/52 is bringing big money if you can even find one! First $12,500 plus shipping takes it! I am an individual selling off parts from my 964 Turbo I put back to stock. Not a shop.
