These wheels were custom made by Fikse for my 997.1 GT3 RS. They may fitter models. Here are the specs:
18" dia, 9" fronts with approx 51.5 offset using Porsche spacer part number 99736160590 (I measured, might not be exact) and 12" rears with 60 offset. If you need the spacer, I will include it for another $100.
Serial numbers on the wheels are:
fronts f320a87071036912 and913
rears f32087100525664 and 665
Yes, on the front, Porsche part number 997.361.605.90. Re look at my post, pls.
actually, i was referring to the rears 60mm et on a 12" is shallow for a widebody. Unless you mean you use the oem 5mm spacer for the rears?? Pretty sure my reading comprehension is on par
Or perhaps you mean you used it without rear spacers but 25mm more inset from optimal?
