2007 Porsche 911 Turbo - Highly Optioned
2007 Porsche 911
  • 2007 Porsche 911 - 2007 Porsche 911 Turbo - Highly Optioned - Used - VIN WP0AD29937S783559 - 63,500 Miles - 6 cyl - AWD - Manual - Coupe - Black - San Jose, CA 95126, United States
HardHitter is offline
    $65,000
  • Location San Jose, CA, 95126, USA
  • VIN WP0AD29937S783559
  • Mileage 63,500
  • Drive Type AWD
  • Exterior Color Black
Up for sale is my 2007 Porsche 911 Turbo with a 6-speed manual transmission. It has had all the major services done, latest being 60k mile service where all fluids, spark plugs, etc were done (have service receipt for documentation). I also just recently replace the battery and brakes (pads, sensors, caliper bolts) where the shop identified a cracked CV boot ($160 part). The car currently has 63,500 miles on it. Clean title car with title in hand. No paint work or accidents.
The car's asking price is $65,000 firm.
Please let me know if there are any questions. Thank you!
The car's build sheet can be seen below:
Build Sheet
MSRP: $144,533
Axel-Differential Lock Rear
Heated Front Seats
Ceramic Composite Brakes - PCCB
Parking Assist System
Sport Chrono Package
Module for Telephone PCM
Remote CD Changer (6 Disc)
Black
Black Full Leather
Storage Compartment Lid with Model Logo
Gear Lever/Handbrake Aluminum/Leather
Black Mats - Porsche Lettering
Adaptive Sport Seats
Standard Rocker Panels Painted
Sport Shifter
Rear Center Console Leather
Thicker Steering Wheel Leather
Porsche Crest in Headrest
Aftermarket items:
Hardwired Valentine V1 Radar in the rear mirror
Cobb AccessPort with Stage 2 tune
Sachs 2.5 Clutch
Speedtech Catless 3.0" X-pipe exhaust
H&R Springs
Owner History
Per the CarFax report I did for the car when I was purchasing it, I would be considered the 6th owner, however based upon the Owner History in CarFax, 3 of the owners look to be car dealerships. Feel free to run your own CarFax, but here are the owner details per my report.
- Owner 1 - 4/13/2006 to 4/7/2010
Vehicle was registered in New Jersey however service records showed to be at The Auto Gallery in Woodland Hills, CA
- Owner 2 - 9/20/2010 to 9/21/2010
Vehicle was registered in Arizona and then offered for sale the next day
- Owner 3 - 11/24/2010 - 2/1/2014
Vehicle was registered in Arizona with service records tied to Porsche North Scottsdale
- Owner 4 - 3/20/2014 - 9/23/2015
Vehicle was registered in California with service records tied to The Auto Gallery in Woodland Hills, CA
- Owner 5 - 9/23/2015 - March 2017
- Owner 6 - March 2017 - Present
My current ownership
Recent Maintenance History with Receipts
- Miles: 56,834 - Transmission/Clutch - Sachs 2.5 Clutch with new OEM flywheel
Customer reported clutch is slipping
Verified Customer's concern, clutch would slip under load
Per request, removed transmission for inspection and found clutch assembly worn out and flywheel has hot spots
Recommend flywheel and clutch assembly to be replaced
Per request, removed and replaced clutch assembly provided by customer. Removed flywheel and replaced with OEM OES flywheel
Re-installed transmission. Bled clutch slave cylinder. Filled and bled cooling system
Road test vehicle to verify repair
- Miles: 59,958 - Major 60K Service
Customer requested major service
Per request, performed major service. Changed engine oil; oil filter; filter o-ring and crush washers
Removed and replaced engine air filter. Removed and replaced in-cabin pollen filter
Removed and replaced all spark plugs. Applied fuel additive and windshield washer solvent
Performed system diagnosis, read out any faults present in DME.
Inspected all under-body panels - ensure all are secured and tight. Passenger side front wheel liner damaged and spoiler was gone.
Inspected coolant level and antifreeze condition. Inspected radiators for blockage or external debris
Inspected brake hoses and lines. Inspected all drive shaft boots for leaks and wear. Checked out ok.
Inspected drive belt condition, serpentine belt need replacement. Serpentine belt replaced. Also removed and replaced fuel filter.
Checked all drains for debris and blockage. Checked out ok.
Checked all doors; lid locks and hood latches for proper function. Checked out ok.
Checked horn; vehicle electrical including turn signal and headlights functionality. Checked out ok.
Checked vehicle warning lights and battery condition. Checked out ok.
Found front brake pads at 6mm remaining and rear pads at 7mm remaining
Found front tires at 7/32" tread depth and rear tires at 5/32" tread depth
- Miles: 61,591 - Exhaust System Installed - Speedtech Catless 3.0 X-Pipe
Exhaust system installed
Replaced all gaskets
Replaced exhaust studs and nuts
Purchased and replaced all front and rear O2 sensors
- Miles: 62,000 - Oil Change
- Miles: 62,625 - New Battery - Bosch Platinum Series
- Miles: 62,745 - New Front & Rear Brake Pads, Sensors & Caliper Bolts
Walk Around Video:
Drive Around Video:
Old 09-28-2018, 11:22 PM
jsheen615
jsheen615's Avatar
has the car been in an accident?
jsheen615 is offline
Old 09-28-2018, 11:26 PM
HardHitter
HardHitter's Avatar
No accidents to my knowledge or per the Carfax.
Old 09-29-2018, 10:04 AM
HardHitter
HardHitter's Avatar
Please do not waste my time with low ball offers.
Old 09-29-2018, 01:27 PM
turb0
turb0's Avatar
I, along with 2 other members, cannot seem to Private Message (PM) you, so maybe PM me. Thanks.
turb0 is offline
Old 09-29-2018, 02:47 PM
HardHitter
HardHitter's Avatar
feel free to reach out to me through email bwatson86@gmail.com
all pm replied to
Old 10-04-2018, 09:20 PM
HardHitter
HardHitter's Avatar
Still available
Old 10-07-2018, 10:17 AM
HardHitter
HardHitter's Avatar
Still available!
Old 10-10-2018, 10:01 AM
HardHitter
HardHitter's Avatar
Let's get this sold. Taking reasonable offers!
Old 10-14-2018, 10:56 AM
HardHitter
HardHitter's Avatar
There is so much interest in the car, but no one is ready to buy! Let me know if there are any questions!
Old 10-18-2018, 10:38 AM
HardHitter
HardHitter's Avatar
Let's get this sold. Bump
Old 10-22-2018, 10:11 AM
mikeTT
mikeTT's Avatar
What was the situation with the damage noted above please?
mikeTT is offline
Old 10-22-2018, 10:13 AM
HardHitter
HardHitter's Avatar
What damage are you speaking of?
Old 10-22-2018, 10:48 AM
mikeTT
mikeTT's Avatar
"Inspected all under-body panels - ensure all are secured and tight. Passenger side front wheel liner damaged and spoiler was gone."
mikeTT is offline
Old 10-22-2018, 11:02 AM
HardHitter
HardHitter's Avatar
Thanks for the clarification. Service was done prior to my ownership. I don't know if they mean front spoiler, but you can see that the front lip spoiler is obviously there. I took a look at the passenger side wheel liner and under the car and there is a crack in the plastic in the wheel liner, underbody seems fine. I've taken pictures to ease your concern. Happy to answer any other questions!
