Drifting taycan
Love it
Awesome. My Model 3 dual motor came to a near complete halt when I tried to do that- the difference between a car built for drivers and one designed to drive itself. I’ll take the former.
Originally Posted by Petevb
(Post 16130544)
I thought Tesla cars can drift, or is that because you have a dual motor system? Or maybe it is just Japan.
Earl Colby Pottinger (Tesla, Taycan, Bollinger, Rivian and other BEVs fan) |
disable the nannies, normally by finding the right fuse and removing it - or disable the wheel sensors - either way it requires you to "hack" the car - there are no customer level settings to allow this type of driving.
Originally Posted by daveo4porsche
(Post 16130745)
Track mode "losens" the nannies it does not disable them…the fast Mode 3 lap times @ laguna have been acomplished with the wheel speed sensors disabled which prevents the system from receiving any wheel data, and therefore it does not intervene.
Originally Posted by freqflyer
(Post 16130716)
Why did it do that? Traction control?
track mode in the Model 3 performance makes the car a little more chuckable - but not much - enough to have fun at laguna - but not enough to drift…
I guess the Taycan can do it because it is made for the track first or is it a select-able option?
Originally Posted by earl pottinger
(Post 16131066)
Here's a prelease Taycan doing even more:
Note: The host got out of the Driver/Engineer, his personal car is an old Corvette. LOL |
(Post 16130544)
the Model 3 Performance in Track Mode will do that all day till the rear tires or the rear brake pads depart the vehicle What I like about this power-on oversteer is the way chirping as the various traction control systems (some in the brakes, some in the motors, some in the rear diff) tried to get all the grip they could find. Maybe that chirping was just the fronts (almost certainly) but it was already over-rotating the rears, so the only (conventional) outcome is for more power to the front to pull the car back into a straight line as the driver flattened out the slip angle. The next step is to find out how long the software in various modes will allow left-foot braking to assist in the weight transfer to get that kind of rotation from a 5000lb+ lump. |
(Post 16130950)
Track Mode doesn't limit slip angle (as far as I can tell) but then it depends if you mean drift in the rally sense (steering with the throttle, steering straight ahead) or the modern day sport of extreme oversteer. |
(Post 16130544)
