Taycan Size?
Taycan Size?
Since pictures don't tell the whole story and dimensions haven't come out or at least I haven't seen them, could someone who's seen the Mission E or Taycan prototypes in person comment on the size?
My preference is that it's significantly smaller than a Panamera.
I saw the Mission-e at PEC Atlanta this year. I was told that it sits slight lower in height and slightly shorter in length than the current Panamera. There wasn’t a Panamera directly next to the Mission-e for visual comparison, but having driven a Loaner Panamera recently this appears to be accurate. Basically, I’m expecting the Taycan to be a baby Panamera in appearance:-)
Mid-size sedan, IMO. If I were to guess, I’d say about the same wheelbase as a Mercedes E class. The test mule versions I have seen pictures of appear to have significantly more height and the front clip looks more like a Panamera.
From the owner's manual:
Dimensions
Length (depending on the equipment) 195 in. (4,963 mm)
Width (depending on the equipment) 77.4 in. (1,966 mm)
Width with door mirrors 84.4 in. (2,144 mm)
Height at empty weight to DIN depending on the chassis variant 53.5 in. (1,359 mm) – 55.2 in. (1,401 mm)
Ground clearance at empty weight according to DIN depending on the the chassis variant 4.2 in. (106 mm) – 5.8 in. (148 mm)
Dimensions
Weird thread to bump...
