Is a Cayman R front bumper compatible with the Spyder?
I’m curious if anyone knows, or have seen a Spyder running a Cayman R bumper with the round fog lights? Would this be a direct swap or is the sub structure different between the cars? This would be for a PDK car.
I did swap 981 boxster bumper for cayman. Its not exactly a direct swap, need a few more new things under the skin. But quite easy if you are DIY type
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
The front wheel well liner on the Cayman R is different... the vents are open allowing air exiting the side radiators to enter the wheel wells, rather than all of that air being forced straight downward through a hole in the floor of the front bumper. That liner is optional through, not a requirement.
Thanks for all this great info. So it sounds like the aero front splitters and fog light grill openings could be retrofitted to a Spyder bumper. I like the round fog lights on the Cayman R, and wondered if it’s ever been added to a Spyder. Thanks for the replies.
upon closer inspection they are quite different. So in order to try it I’d need an entire Cayman front bumper and order the aero kit splitters. My Spider is running a full GT3 style 3rd radiator kit with top vent, so the larger lower center radiator opening of the Cayman bumper is nice.
For the side radiator opening, the Boxster and Spyder bumpers are the same behind the silver trim. A Boxster/Spyder bumper are interchangeable (Spyder bumper is a just a Boxster bumper with two tiny tabs cut off by Porsche). And it's only the lower inner corners on the Boxster/Spyder that are different from a Cayman (85% of the opening is the same shape/size/location). A Boxster/Spyder likely have the same side radiator ducting. Just check to see if that's the same part between any Cayman and any Boxster.
For the center radiator opening, just look up if it's different part numbers between the Spyder and the Cayman. They ducting is different from 987 vs 997, but may be the same for all 987.
Are you confirming the ducting is also different, not just the opening shape? The ducting for the Cayman center opening is flexible and therefore may be the same for all 987. Only the ducting is what matters.
