Spec Boxsters For info sharing on this exciting new class
Oil sump or not?
Old 05-11-2017, 03:23 PM
hf1
hf1's Avatar
Received 1,639 Likes on 1,122 Posts
Originally Posted by 91K-Man
Hi, ok made an error, the 2L Mantis sump is 1.5" thick, so 1.5"- .625"= .875" or 7/8 " deeper than a stock pan. We did not test the 1.2 pan as We are racing, the 1.2 L was meant for 996/997. To give those a bit more ground clearance since the engine hangs off back. The mid engines not an issue. More oil is the plan. The 1.2 L sump is 1" thick.
Great, thx. Can you pls pm me a price quote for the 2L Mantis sump for a SPB shipped to usa zip 06779?
Old 05-11-2017, 03:36 PM
hf1
hf1's Avatar
Originally Posted by jdistefa
Deep sump clearance will be fine unless you straddle some extreme step-off curbing, i.e. outside of T2 trackout at NJMP. Ask me how I know
Yes, that curb looks ominous even without the deep sump.
What happened exactly -- total destruction and oil crap out? Did the motor survive?
Old 05-11-2017, 09:24 PM
RickyBobby
RickyBobby's Avatar
If it were my car I'd ask these guys: John Gladwill. Todd Lamb. Robbie Provost. Quirt Smith. Chris Drake.
Old 05-11-2017, 10:24 PM
jdistefa
jdistefa's Avatar
Just rode on the pan for a bit. Scuffed but otherwise fine. Replaced the drain plug.
Old 05-12-2017, 03:15 AM
hf1
hf1's Avatar
Everyone, pls pm me any pro/con vendor suggestions, research, or data that you don't feel like sharing in public. Need to make a decision and have it done before the WGI club race Jun 2. Thx!
Old 05-12-2017, 03:17 AM
hf1
hf1's Avatar
Thx!
Old 05-12-2017, 10:22 PM
BostonDMD
BostonDMD's Avatar
Thx!
Zoran, you have to include Matt Muller in the list of the guys to ask......you'll find out why at the Glen.....
Old 05-12-2017, 11:24 PM
RennPart
Basic Sponsor
RennPart's Avatar
We run the X51 pan only. We had the 3 qt accusump but after taking advice from Drake and Gladwill we removed the 35lb anchor from the trunk, turns out the auto valve was broken anyways thus leaving the accusump useless. The fast guys don't run the deep pan, or an accusump if that tells you anything. Allso we've heard (and it makes logical sense) that you run the risk of scraping/cracking the deep pan since it sticks out further. The X51 is the same "pan" but with different baffles and we've chipped our pan by an off track field day at VIR.
X51 pan we use: https://rennpart.com/product/x51-oil-pan-kit/
rennpart.com | Phone: 336-793-2134 |Email: ace@rennpart.com
Instagram | Facebook
Old 05-13-2017, 03:58 AM
hf1
hf1's Avatar
Anyone has the RL handles for Gladwill, Lamb, and Smith?
Old 05-13-2017, 04:34 AM
hf1
hf1's Avatar
Thanks Paolo. Already did.
Old 05-13-2017, 07:00 AM
hf1
hf1's Avatar
A little bit of math I did:
The 1.2L pan is 0.95cm lower than stock to add 1.2L oil so it adds 1.2/0.95 = 1.26 liters per 1cm of lost clearance.
The 2L pan is additional 1.27cm lower than the 1.2L pan to add 0.8L oil so it adds only 0.8/1.27 = 0.63 liters per 1cm of lost clearance.
Looks like the first added 1.2 liters cost the least amount of lost clearance. The extra 0.8 liters in the 2L pan come at a much larger cost in lost clearance, making the 1.2L pan a reasonable compromise. Thoughts?
Old 05-13-2017, 07:09 AM
mmuller
mmuller's Avatar
Probably not this year . I will be there and am hoping to drive (trying for the first time since surgery next weekend) but know I won't be competitive given where my health is at right now.
I will be surprised if I run every session to be honest.
Old 05-13-2017, 12:00 PM
PLNewman
PLNewman's Avatar
Matt could run in reverse and beat most of us.
Old 05-13-2017, 12:49 PM
91K-Man
Registered User
91K-Man's Avatar
If you guys are worried about hitting the Mantis deep sump pan, fab skid plate. In 18,000 miles of racing, with many offs , not scratch on mine.Oops, we have had 3 versions on the car Not saying it cant happen. Its flush with frame rails on the cayman and boxsters. I actually went back into the shop and double checked. Yes, its above the frame rails, the 2l sump.
Old 05-13-2017, 01:15 PM
sbelles
I'm in....
sbelles's Avatar
Because of the way that the accusump is plumed, the oil filter ends up being the low spot on mine. Five years ago at the NJMP race, I got pushed inside on a start and straddled the curb in 1. It put a pinhole in the filter that sprayed oil directly on the LR tire. I couldn't figure out there all the oversteer came from until I got back to the paddoc.
Quick Reply: Oil sump or not?
