1997 Spec Boxster For Sale
I bought this car in 2010 and started converting it to SPB with the guidance of HRG and Nick Richards from GSR Autosports. Cage was installed by Norhtern Racing Products in Eagan, MN which specialilzed in Chassis Fabrication. I put it on the track at Hallett in 2011 and it has been raced exactly 9X since then. It has been meticulously maintained, is up to date, and needs nothing. I just installed new front rotors and brake pads (not pictured), new lexan windshield, new Crow belts, new seat back brace, new coil packs and spark plug tubes. Comes ready to race and needs nothing.
Scott.Beamish@gmail.com 612.465.9178 Asking: SOLD Build Sheet: Momo Steering Wheel Momo Adapter Oil Cooler Wheel Stud Kit SPB Conversion Getty SPB Top MAF, Coolant Reservoir, Spark Plugs Bead Blast Aluminum Cam Plugs Accusump Misc Bolts Exhaust Flanges Powder Coating Lexan Windshield Roll Cage Tubing Paint/Exhaust/Misc Extra Rims w/sandblasting powdercoating 5mm Wheel Spacers Snap Off Quick Release Rear Strut Mounts Replace Caliper Seals Elephant Racing Camber Locks Coil Packs and Spark Plug Tubes Traqmate Transponder Spare Transmission Detailed SPB Conversion PSS9's Swift springs Front AR bar Tarett Long drop links Rear AR bar kit GT3 arms and shims Rear MB Toe Links Brake Lines Brake Pads Front Brake Pads Rear Brake Rotor Front Brake Rotor Rear Wheel bearings 3rd radiator kit Mocal Oil Cooler Power Pulley Short Belt IMS Update Rear Main seal Light Flywheel Clutch kit/PP/Disc/TO Front main seal X51 Oil pan Wevo engine mount Wevo Tranny mounts Air Filter Oil Filter Fuel Filter Air/Oil Seperator Water Pump Sparco Pro-ADV Fire Ext Fire Ext mount Tow Hooks (fr & rr) Electrical Cutoff Hardtop (Aftermarket) https://cimg2.ibsrv.net/gimg/rennlis...886b54a4f5.jpg https://cimg3.ibsrv.net/gimg/rennlis...03b7755ddd.jpg https://cimg4.ibsrv.net/gimg/rennlis...874ee05604.jpg https://cimg5.ibsrv.net/gimg/rennlis...2e866641cf.jpg https://cimg6.ibsrv.net/gimg/rennlis...8192357da5.jpg https://cimg7.ibsrv.net/gimg/rennlis...637a21efa9.jpg https://cimg8.ibsrv.net/gimg/rennlis...84e59272e1.jpg https://cimg9.ibsrv.net/gimg/rennlis...f9b3471218.jpg https://cimg0.ibsrv.net/gimg/rennlis...2a104e4159.jpg https://cimg1.ibsrv.net/gimg/rennlis...03f5f06964.jpg https://cimg2.ibsrv.net/gimg/rennlis...332d2aed05.jpg https://cimg3.ibsrv.net/gimg/rennlis...d20583e9b6.jpg https://cimg4.ibsrv.net/gimg/rennlis...e6c278f5fc.jpg https://cimg5.ibsrv.net/gimg/rennlis...5ca662e317.jpg https://cimg7.ibsrv.net/gimg/rennlis...619524ffe2.jpg https://cimg8.ibsrv.net/gimg/rennlis...35ac60ef0c.jpg https://cimg9.ibsrv.net/gimg/rennlis...f66a82e12b.jpg https://cimg1.ibsrv.net/gimg/rennlis...e332b87809.jpg https://cimg2.ibsrv.net/gimg/rennlis...cb54c0a248.jpg https://cimg3.ibsrv.net/gimg/rennlis...7933639399.jpg https://cimg4.ibsrv.net/gimg/rennlis...c8329e4534.jpg https://cimg5.ibsrv.net/gimg/rennlis...3b976b6c64.jpg https://cimg6.ibsrv.net/gimg/rennlis...b410d54677.jpg https://cimg7.ibsrv.net/gimg/rennlis...331cdf7da8.jpg https://cimg8.ibsrv.net/gimg/rennlis...598ce781a4.jpg |
