Brake Pads
#31
Try RS29 front, RST3 rear.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
#33
#34
I'm fascinated by this brake pad chart. Am I reading it right?
If, for instance, one pad has an "8" for Pad Wear, and another pad has a "7" does that mean the first pad will wear MORE or LESS than the second pad?
Same thing for Disk Wear. Does the pad with the HIGHER number wear the disk MORE or LESS?
https://www.paragon-products.com/kb_results.asp?ID=97
#35
#36
I dont run enduro's, that is true. But I do run every practice session back to back and normally do a test and tune day the day before a club race if available. My car got 42 hours on it this year.
#37
#38
Yes it is confusing particularly on the wear categories. A higher number for those categories will mean the pad is better in that area. So a pad with 10 on pad wear will wear better than a pad listed at 8. A pad listed as 9 on disc wear will be less agressive on the disc than a pad listed at 8.
#39
4 sets of pads and 3 sets rotors for the year.
#40
Originally Posted by Coloradoheel
i run PFC08s front and rear. Between NASA, PCA and WRL the car had just over 82 hours of race time this year. Another 50+ hours testing/practice.
That is more time than I have been on the track my entire life
#41
I'm decent but there are many guys much faster than I. I'm getting faster though - made some good progress with a coach this year - need to do that again.
#42
Not that I recall but a good bit of our Pagid sales are online so I don't always see what's on each order. The RST3 may be a bit aggressive on the front at least compared to the RS29. I'd think of the RST3 as a improved RS14. I'd try RS29 front and RST3 rear on your next go around.
#45
