Spec Boxsters For info sharing on this exciting new class
TPS voltage
Old 12-06-2018, 07:34 PM
Lemming
Lemming's Avatar
Default TPS voltage
Adding some inputs for my data acquisition system. I've tapped into the TPS wire and it appears to have a voltage range from 0.5 to 4 volts, which seems strange to me. I know on the low end that many sensors are 0.5 volts, but would have guessed that the high end was 4.5 or 5 volts. Does anyone know the stated TPS voltage for the 986?
Old 12-06-2018, 11:41 PM
C4 Pazzo
C4 Pazzo's Avatar
I don't know the official specs, but on my car 80% indicated equals full throttle (checked manually).
Old 12-10-2018, 04:00 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Don't know this sensor specifically, but most sensors rarely use the full voltage range. the .5v on the top and bottom allows for manufacturing variance and calibration. Saying that, many position sensors will read the full 5v in my experience.
Old 12-10-2018, 05:52 PM
Dave DE
Dave DE's Avatar
I get about 4.2 V at full throttle. '98 spb & traqmate
Old 12-10-2018, 06:56 PM
Lemming
Lemming's Avatar
Is it 4.2v at WOT when engine is running, or with just the key turn on and WOT?
Old 12-11-2018, 10:20 AM
MJP911
MJP911's Avatar
Mine varies between 0.55-3.85v
Old 12-12-2018, 04:40 PM
Dave DE
Dave DE's Avatar
engine running
Quick Reply: TPS voltage
