Optimal ride height?
I have a fully track prepped boxster and will be Installing new dampers and springs this month. Is there an optimal setting for front & rear ride height? or at least a good starting point and or rake? |
Rake at 0 degrees is a good staring point, especially for open diff.
If you have an LSD you can go from 0 to +0.5 deg rake. There`s a minimum allowable ride height for SPB but I can give you a hint and say not optimal re. bump steer. If you aren't running in SPB I would strongly suggest aftermarket rear control arms with bump steer shims. If you have the budget do the same for front outer tie rods. Then you can go `low` and adjust for bump properly. |
Thanks Matt, I do have an lsd and gt3 lower control arms. I also lifted the rack to help with bump steer up front. Where do you shim the rear for bump? |
Originally Posted by Deadeye
(Post 14729452)
Thanks Matt, I do have an lsd and gt3 lower control arms. I also lifted the rack to help with bump steer up front. Where do you shim the rear for bump? http://www.rennline.com/Rear-Toe-Con...nfo/S70.10.41/ |
