SPB Max Deceleration
I have a question prompted by a thread in another forum. What is the max deceleration (g's) you are seeing in the SPB?
The only good data I have at this point comes from Barber Motorsports, where the only hard breaking point is the hairpin which is down hill. There I see just over 1g (1.01 - 1.03) based on Traqmate.
Basic Site Sponsor
Basic Site Sponsor
Received 2,856 Likes
Is the Traqmate ABSOLUTELY level with the car, while the car is on a level surface?
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
If canted forward (nose down) in relation to the car, it can make a difference in the absolute readings (although it’s still ok for comparisons only with that car’s TM generated files).
I will look at some of my IMSA and Historics F1 files, but I would not expect to see a significant difference between T5 and say, T1, in sustained deceleration between them.
What are you getting in T1? T2? T14?
Just measured the traqmate, -1o (lower aft).
Looking through data for Barber now, seeing the following g's (greatest value from a few laps)
T1 0.92
T2 0.6
T5 1.11
T14 0.6
I don't consider T1, 2, or 14 hard braking zones.
T1 0.92
T2 0.6
T5 1.11
T14 0.6
I can achieve 1.2 depending on fresh tires and track surface however max avg is 1.1 in this image you can see 1.2 however I hit the abs on this lap in the zone just prior I achieved max BPS and was able to bleed off before ABS kicked in (still need a lot of improvement in brake release) however only saw 1.07 for max deceleration. Whats interesting is had a semi pro drive the car and they had consistently braked at 1500 psi achieving 1.1 max decel therefore always staying out of ABS but achieving 99 % of max decel everytime so much to continue to learn...
Basic Site Sponsor
Basic Site Sponsor
What's interesting is had a semi pro drive the car and they had consistently braked at 1500 psi achieving 1.1 max decel therefore always staying out of ABS but achieving 99 % of max decel everytime so much to continue to learn...
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Not an SPB, but fun to look at, nonetheless!
I think the #(psi) measurement is dependent on how the individual sensor/system is configured. The sensor in my car is 0-2000 so I set the voltage range on the TM to use 2000 as the max. I agree he ABS hits in different scenarios at different psi my abs hits more frequently as tires go off and is something i need to learn how to adjust for. hitting the abs is not optimal as it upsets the car and lengthens the brake zone
